eric@Eric-PC:~$ sudo apt update
Hit:1 http://archive.ubuntu.com/ubuntu xenial InRelease
Hit:2 http://ppa.launchpad.net/kdenlive/kdenlive-stable/ubuntu xenial InRelease
Hit:3 http://ppa.launchpad.net/teejee2008/ppa/ubuntu xenial InRelease
Hit:4 http://ppa.launchpad.net/webupd8team/java/ubuntu xenial InRelease
Hit:5 http://deb.playonlinux.com precise InRelease
Reading package lists... Done
Building dependency tree
All packages are up to date.
eric@Eric-PC:~$ sudo apt upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 0 B/7,340 B of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
dpkg: dependency problems prevent configuration of ntrack-module-libnl-0:
ntrack-module-libnl-0 depends on libntrack0 (>= 005); however:
Package libntrack0 is not installed.
dpkg: error processing package ntrack-module-libnl-0 (--configure):
dependency problems - leaving unconfigured
dpkg: error processing package libntrack0 (--configure):
package libntrack0 is not ready for configuration
cannot configure (current status 'half-installed')
No apport report written because the error message indicates its a followup error from a previous failure.
libntrack0
I tried fixing things by myself when I tried to delete ntrack-module-libnl-0 and libntrack0 and then re-installing it. But that's not working. I am regretting trying to fix without consulting here so I do not want to do anything else without knowing how to fix this.
This is the following out from sudo apt install -f :
eric@Eric-PC:~$ sudo apt install -f
libntrack0
