In the Terminal, the command
myuser@TomE:~$ sleep 5 && /home/myuser/mountF
myuser@TomE:~$
works OK with mountF containing
#! /bin/bash
pkexec mount -t vfat /dev/sdb7 /home/myuser/F
. But if I place the same command in the Startup Applications dialog and check it, it does not work after I log in, even if I have unchecked the antivirus program there and disconnected external USB disks. In my home directory is a file .xsession-errors, with the logging time, containing
openConnection: connect: No such file or directory
cannot connect to brltty at :0
. Is it related to this problem? (According to the Software Updater, my system is up to date.) Thanks!
Tomáš Pečený
  • 1,507
  • 19
  • 46
Add this to /etc/fstab
sudo nano /etc/fstab
Add in
/dev/sdb7 /home/myuser/F vfat noauto,users,uid=1000,gid=100,dmask=027,fmask=137,utf8  0  0
Now you can mount at login with or without a script and without sudo
mount /dev/sdb7
So just run that command, mount /dev/sdb7 at login, no need for a script or anything complex.
See https://help.ubuntu.com/community/Fstab for details and other options.
Panther
  • 104,528
