From the situation it seems a bit clear that the installation of Ubuntu OS (K-Ubuntu,in this case) was never completed on the desired machine/partition. For if it were successfully done, there would have appeared a grub-menu for OS selection which would list all the Operating-Systems installed on the HDD.
Secondly, about the partition which was untouched during Ubuntu installation and still can't be seen in the windows-explorer, it is so because that partiton was made a swap-partition forcefully during linux/ubuntu installation. Since, you cannot access any partitions with linux files on it through a Windows-explorer thus, this partition also goes invisible when one tries to search for it in Windows-OS.
So,following steps would successfully install a Linux flavor on the desired partition keeping other partitions visible as well as accessible in Windows:
1- Shrink the existing partitions and create a pool of free space for Linux/Ubuntu installation and swap-disk allocation.
2- Create a New-Volume for swap purpose from the free-space created in the first step. This disk should have memory equal to the physical-memory (RAM)the target machine. For further clarification regarding swap-memory reservation check this thread.
3- System now must still have some free-space left (linux/ubuntu os will be installed on this free-space). This should be kept around 20-30 gigs. I myself kept it to 50-GB since i had a list of installations coming my way on the linux/ubuntu OS. Leave this space as free.
4- Make a bootable external-drive with the desired OS (K-Ubuntu 16.04, here).I would recommend Rufus.
5- Move up the extrernal-disk to the top on boot-priority list from the BIOS.
6- Restart the system with external drive in place and initiate the Ubuntu installation process.Manually setup the installation-partition and swap-partition. Select the 'free-space' you created earlier as the primary partition for Ubuntu-installation and hit next.
7- A prompt will ask to confirm if one wants to allocate a partition for swapping or not. This is where you have to hit the back button and select the New-Volume that was created earlier. Hit Install and sit back while the ubuntu gets installed.
8- Restart the system without the USB. A boot-loader menu will ask you to select an OS to boot with. Select Ubuntu and patrol the whole OS to check if everything it working smooth.
9- Restart the system and boot the Windows-OS. Check for the partitions you expect to be visible and accessible.
You would not be able to see the partitions where Ubuntu/Linux is installed and the partition allotted for swapping. Remaining partition would be accessible and writable permanently.
