jan@XXXXX:~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run ‘apt-get -f install’ to correct these.
The following packages have unmet dependencies.
linux-image-extra-4.4.0-87-generic : Depends: linux-image-4.4.0-87-generic but it is not installed
linux-image-extra-4.4.0-92-generic : Depends: linux-image-4.4.0-92-generic but it is not installed
linux-image-generic : Depends: linux-image-4.4.0-92-generic but it is not installed
Recommends: thermald but it is not installed
E: Unmet dependencies. Try using -f.
so I run apt-get -f install
jan@XXXXX:~$ sudo apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
linux-headers-4.4.0-62 linux-headers-4.4.0-62-generic linux-headers-4.4.0-64
linux-headers-4.4.0-64-generic linux-headers-4.4.0-66
linux-headers-4.4.0-66-generic linux-headers-4.4.0-70
linux-headers-4.4.0-70-generic linux-headers-4.4.0-71
linux-headers-4.4.0-71-generic linux-headers-4.4.0-72
linux-headers-4.4.0-72-generic linux-headers-4.4.0-75
linux-headers-4.4.0-75-generic linux-headers-4.4.0-78
linux-headers-4.4.0-78-generic linux-headers-4.4.0-87
linux-headers-4.4.0-87-generic linux-image-4.4.0-62-generic
linux-image-4.4.0-64-generic linux-image-4.4.0-66-generic
linux-image-4.4.0-70-generic linux-image-4.4.0-71-generic
linux-image-4.4.0-72-generic linux-image-4.4.0-75-generic
linux-image-4.4.0-78-generic linux-image-4.4.0-87-generic
linux-image-extra-4.4.0-62-generic linux-image-extra-4.4.0-64-generic
linux-image-extra-4.4.0-66-generic linux-image-extra-4.4.0-70-generic
linux-image-extra-4.4.0-71-generic linux-image-extra-4.4.0-72-generic
linux-image-extra-4.4.0-75-generic linux-image-extra-4.4.0-78-generic
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
linux-image-4.4.0-87-generic linux-image-4.4.0-92-generic
Suggested packages:
fdutils linux-doc-4.4.0 | linux-source-4.4.0 linux-tools
The following NEW packages will be installed
0 to upgrade, 2 to newly install, 0 to remove and 95 not to upgrade.
15 not fully installed or removed.
Need to get 0 B/43.9 MB of archives.
After this operation, 134 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 451167 files and directories currently installed.)
Preparing to unpack .../linux-image-4.4.0-92-generic_4.4.0-92.115_amd64.deb ...
Done.
Unpacking linux-image-4.4.0-92-generic (4.4.0-92.115) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-92-generic_4.4.0-92.115_amd64.deb (--unpack):
cannot copy extracted data for './boot/System.map-4.4.0-92-generic' to '/boot/System.map-4.4.0-92-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-92-generic /boot/vmlinuz-4.4.0-92-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-92-generic /boot/vmlinuz-4.4.0-92-generic
Preparing to unpack .../linux-image-4.4.0-87-generic_4.4.0-87.110_amd64.deb ...
Done.
Unpacking linux-image-4.4.0-87-generic (4.4.0-87.110) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-87-generic_4.4.0-87.110_amd64.deb (--unpack):
cannot copy extracted data for './boot/vmlinuz-4.4.0-87-generic' to '/boot/vmlinuz-4.4.0-87-generic.dpkg-new': failed to write (No space left on device)
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-87-generic /boot/vmlinuz-4.4.0-87-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-87-generic /boot/vmlinuz-4.4.0-87-generic
And it just won't update itself...
Any help would be welcome...
Thanks
