enter image description hereThis is a weird problem. My machine has an NVIDIA GeForce GTX 1070 and, having recently reinstalled with Ubuntu 16.04-3, I now cannot see any of the characters of the boot messages. I have encrypted file systems so need to enter the password as the machine boots.
I already knew that I needed to change the boot parameters to get the keyboard to work with the encrypted file systems so have nosplash set. I also have nomodeset since there seems to be a known problem with the 1070 graphics card.
What I'm seeing is a blank screen but not a really blank screen (I said it was weird). Rather than trying to describe this I have taken a photo of my monitor.
As you can see there are black lines where there should be characters. I can type in my password and the machine boots fine, I just can't see any of the boot messages.
I'm using the NVIDIA closed source driver version 384.59.
Edit your GRUB config and change quiet splash to text. To do this during boot, press e to edit, or to do it after you booted use:
sudo nano /etc/default/grub
sudo update-grub
then reboot. This will boot showing you all messages instead of the splash screen.
user8292439
  • 3,878
  • 32
  • 57
Solved! I removed the following line from my grub.cfg file:
gfxmode $linux_gfx_mode
And now I can see all the boot messages!
