I am working in TinyOs in Ubuntu 16.04. When I run the Blink program, the following error occurs:
[INFO] script
2538 bytes in ROM
56 bytes in RAM
[INFO] size (toolchain):
text data bss dec hex filename
2596 2 56 2654 a5e build/telosb/main.exe
[INFO] generating symbol table
[INFO] generating listing
[INFO] creating ihex file
[INFO] writing TOS image
[INFO] writing TOS buildinfo
[INFO] running the wiring check
<JAVA_HOME>/lib/ext exists, extensions mechanism no longer supported; Use
-classpath instead.
.Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
../../support/make/Makerules:362: recipe for target 'wiring_check' failed
make: *** [wiring_check] Error 1
Can anyone tell why this error occured?
