First of all I am a newcomer in Ubuntu. I want to use my bit-locker encrypted internal hard drive in Ubuntu 16.04 LTS 32 bit system. So I have downloaded dislocker (dislocker-master.zip).
The extracted zip file compiled and installed Dislocker on Ubuntu according to the instruction given in INSTALL.md file. To use Dislocker they have written as
Once installed, see dislocker(1) for details on how to use it.
in INSTALL.md file but I cannot find dislocker(1) anywhere in the extracted zip file. So I searched on Google that how to use it and I found tutorial on https://www.youtube.com/watch?v=n7XT5fK4iwA.
According to this, last line in terminal
sudo mount -o loop /media/drive1/dislocker-file /media/mount1/
shows the error:
ntfs-3g-mount: mount failed: Permission denied
To fix this, I searched on Google and found a command on https://github.com/Aorimn/dislocker/issues/86, so I used the command:
sudo mount -o ro,loop /media/drive1/dislocker-file /media/mount1/
which opens the Bitlocker-encrypted drive as read-only. But I want write access also. How can I do that?
Things I have tried:
$ sudo chown  jin:jin drive1
chown: changing ownership of 'drive1': Function not implemented
$ chmod 777 drive1/
error: chmod: changing permissions of 'drive1/': Function not implemented
I have also checked Use (Windows) BitLocker-encrypted drive on Ubuntu 14.04 LTS with result (my password is starting with 1):
$ sudo dislocker -r -V /dev/sda3 -123*** -- /media/drive1
dislocker: invalid option -- '1'
dislocker by Romain Coltel, v0.7.1 (compiled for Linux/x86)
Usage: dislocker [-hqrsv] [-l LOG_FILE] [-O OFFSET] [-V VOLUME DECRYPTMETHOD -F[N]] [-- ARGS...]
    with DECRYPTMETHOD = -p[RECOVERY_PASSWORD]|-f BEK_FILE|-u[USER_PASSWORD]|-k FVEK_FILE|-c
Options:
    -c, --clearkey        decrypt volume using a clear key (default)
    -f, --bekfile BEKFILE
                          decrypt volume using the bek file (on USB key)
    -F, --force-block=[N] force use of metadata block number N (1, 2 or 3)
    -h, --help            print this help and exit
    -k, --fvek FVEK_FILE  decrypt volume using the FVEK directly
    -l, --logfile LOG_FILE
                          put messages into this file (stdout by default)
    -O, --offset OFFSET   BitLocker partition offset, in bytes (default is 0)
    -p, --recovery-password=[RECOVERY_PASSWORD]
                          decrypt volume using the recovery password method
    -q, --quiet           do NOT display anything
    -r, --readonly        do not allow to write on the BitLocker volume
    -s, --stateok         do not check the volume's state, assume it's ok to mount it
    -u, --user-password=[USER_PASSWORD]
                          decrypt volume using the user password method
    -v, --verbosity       increase verbosity (CRITICAL errors are displayed by default)
    -V, --volume VOLUME   volume to get metadata and keys from
    --                    end of program options, beginning of FUSE's ones
  ARGS are any arguments you want to pass to FUSE. You need to pass at least
the mount-point.
Tue Aug 22 14:16:09 2017 [CRITICAL] Failed to open : No such file or directory
*** Error in `dislocker': corrupted size vs. prev_size: 0x816bb090 ***
======= Backtrace: =========
/lib/i386-linux-gnu/libc.so.6(+0x67377)[0xb755c377]
/lib/i386-linux-gnu/libc.so.6(+0x6d2f7)[0xb75622f7]
/lib/i386-linux-gnu/libc.so.6(+0x6d6ce)[0xb75626ce]
/lib/i386-linux-gnu/libc.so.6(+0x6e395)[0xb7563395]
/lib/i386-linux-gnu/libc.so.6(_IO_setb+0x61)[0xb7560171]
/lib/i386-linux-gnu/libc.so.6(_IO_file_close_it+0xa3)[0xb755e8b3]
/lib/i386-linux-gnu/libc.so.6(fclose+0x89)[0xb7552a69]
/usr/local/lib/libdislocker.so.0.7(dis_stdio_end+0x2b)[0xb76b1150]
/usr/local/lib/libdislocker.so.0.7(dis_destroy+0x68)[0xb76af4cf]
/usr/local/lib/libdislocker.so.0.7(dis_initialize+0xe6)[0xb76af5c8]
dislocker(main+0xe8)[0x80095eb2]
/lib/i386-linux-gnu/libc.so.6(__libc_start_main+0xf7)[0xb750d637]
dislocker(+0x951)[0x80095951]
======= Memory map: ========
80095000-80097000 r-xp 00000000 08:06 550017     /usr/local/bin/dislocker-fuse
80097000-80098000 r--p 00001000 08:06 550017     /usr/local/bin/dislocker-fuse
80098000-80099000 rw-p 00002000 08:06 550017     /usr/local/bin/dislocker-fuse
816bb000-816dc000 rw-p 00000000 00:00 0          [heap]
b6f00000-b6f21000 rw-p 00000000 00:00 0
b6f21000-b7000000 ---p 00000000 00:00 0
b707b000-b7097000 r-xp 00000000 08:06 1588       /lib/i386-linux-gnu/libgcc_s.so.1
b7097000-b7098000 rw-p 0001b000 08:06 1588       /lib/i386-linux-gnu/libgcc_s.so.1
b70ae000-b70b0000 rw-p 00000000 00:00 0
b70b0000-b7103000 r-xp 00000000 08:06 1620       /lib/i386-linux-gnu/libm-2.23.so
b7103000-b7104000 r--p 00052000 08:06 1620       /lib/i386-linux-gnu/libm-2.23.so
b7104000-b7105000 rw-p 00053000 08:06 1620       /lib/i386-linux-gnu/libm-2.23.so
b7105000-b710e000 r-xp 00000000 08:06 1560       /lib/i386-linux-gnu/libcrypt-2.23.so
b710e000-b710f000 r--p 00008000 08:06 1560       /lib/i386-linux-gnu/libcrypt-2.23.so
b710f000-b7110000 rw-p 00009000 08:06 1560       /lib/i386-linux-gnu/libcrypt-2.23.so
b7110000-b7137000 rw-p 00000000 00:00 0
b7137000-b71c1000 r-xp 00000000 08:06 528942     /usr/lib/i386-linux-gnu/libgmp.so.10.3.0
b71c1000-b71c2000 r--p 00089000 08:06 528942     /usr/lib/i386-linux-gnu/libgmp.so.10.3.0
b71c2000-b71c3000 rw-p 0008a000 08:06 528942     /usr/lib/i386-linux-gnu/libgmp.so.10.3.0
b71c3000-b71c4000 rw-p 00000000 00:00 0
b71c4000-b746a000 r-xp 00000000 08:06 535258     /usr/lib/i386-linux-gnu/libruby-2.3.so.2.3.0
b746a000-b746e000 r--p 002a5000 08:06 535258     /usr/lib/i386-linux-gnu/libruby-2.3.so.2.3.0
b746e000-b746f000 rw-p 002a9000 08:06 535258     /usr/lib/i386-linux-gnu/libruby-2.3.so.2.3.0
b746f000-b7476000 rw-p 00000000 00:00 0
b7476000-b74cd000 r-xp 00000000 08:06 535153     /usr/lib/i386-linux-gnu/libmbedcrypto.so.2.2.1
b74cd000-b74ce000 ---p 00057000 08:06 535153     /usr/lib/i386-linux-gnu/libmbedcrypto.so.2.2.1
b74ce000-b74d0000 r--p 00057000 08:06 535153     /usr/lib/i386-linux-gnu/libmbedcrypto.so.2.2.1
b74d0000-b74d1000 rw-p 00059000 08:06 535153     /usr/lib/i386-linux-gnu/libmbedcrypto.so.2.2.1
b74d1000-b74d3000 rw-p 00000000 00:00 0
b74d3000-b74ec000 r-xp 00000000 08:06 1694       /lib/i386-linux-gnu/libpthread-2.23.so
b74ec000-b74ed000 r--p 00018000 08:06 1694       /lib/i386-linux-gnu/libpthread-2.23.so
b74ed000-b74ee000 rw-p 00019000 08:06 1694       /lib/i386-linux-gnu/libpthread-2.23.so
b74ee000-b74f0000 rw-p 00000000 00:00 0
b74f0000-b74f3000 r-xp 00000000 08:06 1574       /lib/i386-linux-gnu/libdl-2.23.so
b74f3000-b74f4000 r--p 00002000 08:06 1574       /lib/i386-linux-gnu/libdl-2.23.so
b74f4000-b74f5000 rw-p 00003000 08:06 1574       /lib/i386-linux-gnu/libdl-2.23.so
b74f5000-b76a5000 r-xp 00000000 08:06 1550       /lib/i386-linux-gnu/libc-2.23.so
b76a5000-b76a7000 r--p 001af000 08:06 1550       /lib/i386-linux-gnu/libc-2.23.so
b76a7000-b76a8000 rw-p 001b1000 08:06 1550       /lib/i386-linux-gnu/libc-2.23.so
b76a8000-b76ab000 rw-p 00000000 00:00 0
b76ab000-b76c7000 r-xp 00000000 08:06 550014     /usr/local/lib/libdislocker.so.0.7.1
b76c7000-b76c8000 r--p 0001b000 08:06 550014     /usr/local/lib/libdislocker.so.0.7.1
b76c8000-b76c9000 rw-p 0001c000 08:06 550014     /usr/local/lib/libdislocker.so.0.7.1
b76c9000-b76f8000 r-xp 00000000 08:06 1587       /lib/i386-linux-gnu/libfuse.so.2.9.4
b76f8000-b76f9000 ---p 0002f000 08:06 1587       /lib/i386-linux-gnu/libfuse.so.2.9.4
b76f9000-b7702000 r--p 0002f000 08:06 1587       /lib/i386-linux-gnu/libfuse.so.2.9.4
b7702000-b7703000 rw-p 00038000 08:06 1587       /lib/i386-linux-gnu/libfuse.so.2.9.4
b7718000-b771b000 rw-p 00000000 00:00 0
b771b000-b771d000 r--p 00000000 00:00 0          [vvar]
b771d000-b771f000 r-xp 00000000 00:00 0          [vdso]
b771f000-b7741000 r-xp 00000000 08:06 1522       /lib/i386-linux-gnu/ld-2.23.so
b7741000-b7742000 rw-p 00000000 00:00 0
b7742000-b7743000 r--p 00022000 08:06 1522       /lib/i386-linux-gnu/ld-2.23.so
b7743000-b7744000 rw-p 00023000 08:06 1522       /lib/i386-linux-gnu/ld-2.23.so
bff87000-bffa8000 rw-p 00000000 00:00 0          [stack]
Aborted (core dumped)
What does it mean? I tried the command for key recovery key,
$ sudo dislocker -r -V /dev/sdaX -p1536987-000000-000000-000000-000000-000000-000000-000000 -- /media/bitlocker
and password,
$ sudo dislocker -r -V /dev/sda3 -u -- /media/drive1
which worked fine but the command
$ mount -r -o loop dislocker-file /media/mount
with -r option does not give any error but opens the drive in read-only mode and without -r option gives same error: permission denied.
I also checked the comment:
Dislocker should support read-write (rw) access to some Bitlocker containers/versions, "the source" link says windows 8 rw access wasn't supported yet" (in 2014) and a comment says it would silently mount as ro (even though mount shows as rw)" probably leading to the mount error ntfs-3g-mount: mount failed: Permission denied. Omitting the -r option to Dislocker & mount should try mounting rw
Xen2050 Jan 25 at 10:45
But does not understand any. Does it mean that drive encrypted with bitlocker of windows 7 can open in write mode? I tried with the drive encrypted with bitlocker of windows 7 but it also throws the same error and opens only in read mode. Now how can I enable write access in my Bitlocker-encrypted drive with Ubuntu?
David Foerster
  • 36,890
  • 56
  • 97
  • 151
darshit
  • 31
Can you try this to mount the dislocker-file as a loop device and give everyone permission to write to it:
sudo mount -o loop,umask=0,uid=nobody,gid=nobody /media/drive1/dislocker-file /media/mount1
vidarlo
  • 23,497
If you did not figure this out by now,
mkdir /media/dislocker mkdir /media/windows
Make sure here you don't use the -r option
dislocker -V /dev/sdax -pxxxxxx-xxxxxx-xxxxxx-xxxxxx-xxxxxx-xxxxxx-xxxxxx-xxxxxx -- /media/dislocker
mount -o loop /media/dislocker/dislocker-file /media/windows
Additionally, to this answer you can mount the /media/drive1/dislocker-file with any uid, gid you like, e.g.:
sudo mount -o loop,uid=<myUserId>,gid=<myGroupId> /media/drive1/dislocker-file /media/mount1
Then, you can access any file in /media/mount1 from your user account.
If sudo mount -o ro,loop /media/drive1/dislocker-file /media/mount1/ it's because ro means read-only. Change it it rw and you should obtain write access.
To Do
  • 15,833
