Three or four days ago I was in Best Buy and bought a new Desktop...basically on impulse. It is, to be exact, a Lenovo 310S-08IAP natively running Windows 10. (https://www.cnet.com/products/lenovo-310s-08iap-pentium-j4205-1-5-ghz-4-gb-500-gb/specs/)
I got it home, unboxed it and set it up, and powered it up to make sure it worked as intended from the factory. I used it for some web browsing and a couple of other very brief, routine tasks and everything seemed fine. So I immediately set about the task of installing Xubuntu on it.
[You can safely skip this entire bracketed section if you like, it's just a little background information. (I'm fully aware I have a tendency to bloviate in writing, so, it won't hurt my feelings.)
I was unaware at the time of purchase of all the boot configuration changes that came along with, I guess, Windows 8(?). This is my first new computer in...years. I have an ancient desktop that's run Xubuntu, exclusively, without problem, for years. A 2011 Macbook Pro, same situation. And five Raspberry Pi's which I use to boot various Linux distributions. My point is, I consider myself a long-time linux fan and a pretty competent user. I always try to solve any issues I encounter myself because that's how you learn, and, frankly, it's fun and I enjoy doing it. That said, I'm an electrical engineering student, classes start back tomorrow and I expect free time after today to be at a premium until, basically, next summer. So I'd like to get this solved ASAP and frankly I'm not really sure where to begin with this one.]
After the installation, I was configuring things to my liking when the machine just powered off. I booted it back up and began the task anew and after 5 or 10 minutes it happened again. I thought "that's strange."
So, to this point, my efforts have basically involved removing and reinstalling Xubuntu using various methods. (Being a brand new machine I wasn't afraid of losing anything important.) I tried, for instance, setting up partitions (including one with about 10 gigs of swap space) from within Windows, installing Xubuntu, and I had the problem. I tried partitioning drives from the Xubuntu installer and installing alongside Windows, I have the problem. I tried wiping the thing from the Xubuntu installer and installing Xubuntu stand alone, I have the problem. I removed any trace of Xubuntu and reinstalled Windows and the thing runs like a dream. (Or as close to a dream as a Windows machine can get.) Finally, with both Windows and Xubuntu on the machine, I experience the problem when booted into Xubuntu, but not when booted into Windows.
This post is finally, mercifully, over. I'm not really sure where to go from here and I would greatly appreciate any help, even if it's just a gentle nudge in the appropriate direction. Thanks!
Per request, the results of grep -i -e temp -e therm /var/log/syslog*:
phillip@ZZ9-Plural-Z-Alpha:~$ grep -i -e temp -e therm /var/log/syslog*
Aug 20 12:44:00 ZZ9-Plural-Z-Alpha kernel: [ 0.022829] CPU0: Thermal monitoring enabled (TM1)
Aug 20 12:44:00 ZZ9-Plural-Z-Alpha systemd[1]: Started Daily Cleanup of Temporary Directories.
Aug 20 12:44:00 ZZ9-Plural-Z-Alpha systemd[1]: Starting Thermal Daemon Service...
Aug 20 12:44:00 ZZ9-Plural-Z-Alpha kernel: [ 1.557352] thermal LNXTHERM:00: registered as thermal_zone0
Aug 20 12:44:00 ZZ9-Plural-Z-Alpha kernel: [ 1.557354] ACPI: Thermal Zone [TZ01] (35 C)
Aug 20 12:44:00 ZZ9-Plural-Z-Alpha systemd[1]: Started Thermal Daemon Service.
Aug 20 12:44:00 ZZ9-Plural-Z-Alpha thermald[748]: 21 CPUID levels; family:model:stepping 0x6:5c:9 (6:92:9)
Aug 20 12:44:00 ZZ9-Plural-Z-Alpha thermald[748]: Polling mode is enabled: 4
Aug 20 12:44:01 ZZ9-Plural-Z-Alpha sensors[852]: temp1: +36.0°C (crit = +100.0°C)
Aug 20 12:44:01 ZZ9-Plural-Z-Alpha sensors[852]: coretemp-isa-0000
Aug 20 12:44:01 ZZ9-Plural-Z-Alpha thermald[748]: sysfs read failed constraint_0_max_power_uw
Aug 20 12:44:10 ZZ9-Plural-Z-Alpha systemd[1]: Starting LSB: disk temperature monitoring daemon...
Aug 20 12:44:10 ZZ9-Plural-Z-Alpha systemd[1]: Started LSB: disk temperature monitoring daemon.
Aug 20 12:58:54 ZZ9-Plural-Z-Alpha systemd[1]: Starting Cleanup of Temporary Directories...
Aug 20 12:58:54 ZZ9-Plural-Z-Alpha systemd[1]: Started Cleanup of Temporary Directories.
Aug 20 13:06:58 ZZ9-Plural-Z-Alpha kernel: [ 0.022804] CPU0: Thermal monitoring enabled (TM1)
Aug 20 13:06:58 ZZ9-Plural-Z-Alpha systemd[1]: Started Daily Cleanup of Temporary Directories.
Aug 20 13:06:58 ZZ9-Plural-Z-Alpha systemd[1]: Starting Thermal Daemon Service...
Aug 20 13:06:58 ZZ9-Plural-Z-Alpha kernel: [ 1.555336] thermal LNXTHERM:00: registered as thermal_zone0
Aug 20 13:06:58 ZZ9-Plural-Z-Alpha kernel: [ 1.555338] ACPI: Thermal Zone [TZ01] (35 C)
Aug 20 13:06:58 ZZ9-Plural-Z-Alpha sensors[840]: temp1: +36.0°C (crit = +100.0°C)
Aug 20 13:06:58 ZZ9-Plural-Z-Alpha sensors[840]: coretemp-isa-0000
Aug 20 13:06:59 ZZ9-Plural-Z-Alpha systemd[1]: Started Thermal Daemon Service.
Aug 20 13:06:59 ZZ9-Plural-Z-Alpha thermald[779]: 21 CPUID levels; family:model:stepping 0x6:5c:9 (6:92:9)
Aug 20 13:06:59 ZZ9-Plural-Z-Alpha thermald[779]: Polling mode is enabled: 4
Aug 20 13:06:59 ZZ9-Plural-Z-Alpha thermald[779]: sysfs read failed constraint_0_max_power_uw
Aug 20 13:07:07 ZZ9-Plural-Z-Alpha systemd[1]: Starting LSB: disk temperature monitoring daemon...
Aug 20 13:07:07 ZZ9-Plural-Z-Alpha systemd[1]: Started LSB: disk temperature monitoring daemon.
Aug 20 17:13:00 ZZ9-Plural-Z-Alpha systemd[1]: Started Daily Cleanup of Temporary Directories.
Aug 20 17:13:00 ZZ9-Plural-Z-Alpha kernel: [ 0.022793] CPU0: Thermal monitoring enabled (TM1)
Aug 20 17:13:00 ZZ9-Plural-Z-Alpha systemd[1]: Starting Thermal Daemon Service...
Aug 20 17:13:00 ZZ9-Plural-Z-Alpha kernel: [ 1.550742] thermal LNXTHERM:00: registered as thermal_zone0
Aug 20 17:13:00 ZZ9-Plural-Z-Alpha kernel: [ 1.550744] ACPI: Thermal Zone [TZ01] (28 C)
Aug 20 17:13:01 ZZ9-Plural-Z-Alpha systemd[1]: Started Thermal Daemon Service.
Aug 20 17:13:01 ZZ9-Plural-Z-Alpha thermald[799]: 21 CPUID levels; family:model:stepping 0x6:5c:9 (6:92:9)
Aug 20 17:13:01 ZZ9-Plural-Z-Alpha thermald[799]: Polling mode is enabled: 4
Aug 20 17:13:01 ZZ9-Plural-Z-Alpha sensors[878]: temp1: +30.0°C (crit = +100.0°C)
Aug 20 17:13:01 ZZ9-Plural-Z-Alpha sensors[878]: coretemp-isa-0000
Aug 20 17:13:01 ZZ9-Plural-Z-Alpha thermald[799]: sysfs read failed constraint_0_max_power_uw
Aug 20 17:13:10 ZZ9-Plural-Z-Alpha systemd[1]: Starting LSB: disk temperature monitoring daemon...
Aug 20 17:13:10 ZZ9-Plural-Z-Alpha systemd[1]: Started LSB: disk temperature monitoring daemon.
Aug 20 17:17:50 ZZ9-Plural-Z-Alpha systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Aug 20 17:17:50 ZZ9-Plural-Z-Alpha systemd[1]: Stopping Thermal Daemon Service...
Aug 20 17:17:50 ZZ9-Plural-Z-Alpha thermald[799]: Terminating ...
Aug 20 17:18:21 ZZ9-Plural-Z-Alpha systemd[1]: Started Daily Cleanup of Temporary Directories.
Aug 20 17:18:21 ZZ9-Plural-Z-Alpha systemd[1]: Starting Thermal Daemon Service...
Aug 20 17:18:21 ZZ9-Plural-Z-Alpha sensors[850]: temp1: +34.0°C (crit = +100.0°C)
Aug 20 17:18:21 ZZ9-Plural-Z-Alpha sensors[850]: coretemp-isa-0000
Aug 20 17:18:21 ZZ9-Plural-Z-Alpha kernel: [ 0.022905] CPU0: Thermal monitoring enabled (TM1)
Aug 20 17:18:21 ZZ9-Plural-Z-Alpha kernel: [ 1.551030] thermal LNXTHERM:00: registered as thermal_zone0
Aug 20 17:18:21 ZZ9-Plural-Z-Alpha kernel: [ 1.551032] ACPI: Thermal Zone [TZ01] (32 C)
Aug 20 17:18:22 ZZ9-Plural-Z-Alpha systemd[1]: Started Thermal Daemon Service.
Aug 20 17:18:22 ZZ9-Plural-Z-Alpha thermald[846]: 21 CPUID levels; family:model:stepping 0x6:5c:9 (6:92:9)
Aug 20 17:18:22 ZZ9-Plural-Z-Alpha thermald[846]: Polling mode is enabled: 4
Aug 20 17:18:22 ZZ9-Plural-Z-Alpha thermald[846]: sysfs read failed constraint_0_max_power_uw
Aug 20 17:18:30 ZZ9-Plural-Z-Alpha systemd[1]: Starting LSB: disk temperature monitoring daemon...
Aug 20 17:18:30 ZZ9-Plural-Z-Alpha systemd[1]: Started LSB: disk temperature monitoring daemon.
Aug 20 17:33:23 ZZ9-Plural-Z-Alpha systemd[1]: Starting Cleanup of Temporary Directories...
Aug 20 17:33:23 ZZ9-Plural-Z-Alpha systemd[1]: Started Cleanup of Temporary Directories.
