I'm new to Ubuntu.
I have a dev test server at home, and we are working on it with a friend.
We use SSH, FTP, and also some port for mail, web, ect...
I want to allow only our ip from where we are working on this server :
  • Local network
  • IP from my office
  • IP from my friend
  • IP from my friend office (We work on the server from office for test too)
I've check the logs and I see a lot of try, some people try to login as root, this is why I want to allow only my friend and I to login. But as it's a Web server, we must keep Web and Mail ports open for incoming.
Not sure if I explain fine. How I can do that ? I already try iptable with no luck, still a lot of incoming connection and attempt to login as root.
Can you please let me know how I can proceed easy ?
Thanks and best regards, GP
gprime
For your scenario you need setup iptables rules for this . Also you can user firewalld which is rich command for managing firewall in Linux . I'll explain iptables here .
Iptables is for ipv4/ipv6 packet filtering for Linux kernel . In iptables there are three default tables which each of them contain three default chains :
  1. Input
  2. Output
  3. Forward
Iptables command is following with different options . For your scenario as an example you need to write following commands :
$ iptables -A INPUT -p tcp --dport 22 -m state --state NEW,ESTABLISHED -s x.x.x.x -j ACCEPT
$ iptables -A INPUT -j DROP
These commands only accept ssh connection from port 22 from IP x.x.x.x and every incoming packets will be drop . You can do it for any IP and any Ports you want to server answer . For incoming packets that you don't know which states are use RELATED and INVALID in --state .
You should notice that iptables is sequential rule order . As an example if you block every thing then accept some then you wouldn't get any result because when incoming packet match any rule other rules wouldn't be considered .
Ali Ghasempour
  • 449
