How do I fix this so that i get to use the GUI desktop. I want to run ubuntu 17 from the disk.
Asked
Active
Viewed 980 times
Insert the USB flash drive into a USB port. Power on the computer, hit the (typically) F12 key (or other key called out on the splash screen) to reach the Boot Menu. This occurs before you see the GRUB screen. Select USB from that menu and if you've built a bootable USB flash drive, it'll boot up. Then at the GRUB menu, choose Try Ubuntu.
heynnema
- 73,649
