Is there any way by command-line (no softwares) to set a keyboard shortcut to toggle between 2 commands using the same shortcut key combination. Actually, i wanted to toggle my mousepad when using mouse.
Asked
Active
Viewed 278 times
Yes, it is possible. First you need to identify your touchpad. Run xinput list (you might have to install xinput with sudo apt install xinput first). On my system, that shows:
$ xinput list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ TPPS/2 IBM TrackPoint id=16 [slave pointer (2)]
⎜ ↳ Logitech USB Receiver id=12 [slave pointer (2)]
⎜ ↳ Logitech M325 id=10 [slave pointer (2)]
⎜ ↳ SynPS/2 Synaptics TouchPad id=15 [slave pointer (2)]
⎜ ↳ Logitech USB Receiver id=11 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Sleep Button id=9 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Integrated Camera id=13 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Logitech USB Receiver id=18 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=14 [slave keyboard (3)]
↳ Video Bus id=8 [slave keyboard (3)]
↳ ThinkPad Extra Buttons id=17 [slave keyboard (3)]
So, my touchpad is called SynPS/2 Synaptics TouchPad. Find out the name of yours and then modify this script accordingly:
#!/bin/bash
## Change this value to whatever your touchpad is called
touchpad='SynPS/2 Synaptics TouchPad'
status=$(xinput list-props "$touchpad" | grep "Device Enabled" | gawk '{print $NF}');
if (( $status==1 )); then
xinput -set-int-prop "$touchpad" "Device Enabled" 8 0
else
xinput -set-int-prop "$touchpad" "Device Enabled" 8 1
fi
Save that script as ~/bin/toggle_touchpad.sh and then use your desktop environment's GUI to assign a shortcut to it. The shortcut will now run the script and toggle the touchpad as desired.
terdon
- 104,119
