I have been trying to change the Grub to set Linux-Ubuntu as default option with no success since now I have to enter first to boot menu otherwise Windows starts. I have changed the /etc/default/grubg file as well as used the Grub Customizer App but apparently my laptop doesn't seem to accept the changes, it keeps loading Windows as default boot option.
Specifically I have been changing the lines within the /etc/default/grub file. The current status of the file is the following:
GRUB_DEFAULT=saved
GRUB_SAVEDEFAULT="true"
#GRUB_HIDDEN_TIMEOUT="0"
GRUB_HIDDEN_TIMEOUT_QUIET="true"
GRUB_TIMEOUT="10"
GRUB_DISTRIBUTOR="`lsb_release -i -s 2> /dev/null || echo Debian`"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_idle.max_cstate=1"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL="console"
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE="640x480"
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID="true"
I have tried changing the default with several numbers from 0 to 2 and to switch on and off the option GRUB_SAVEDEFAULT="true" but the Laptop keeps behaving the same way.
I solved the issue thanks to oldfred's suggestion, specifically this link helped http://askubuntu.com/questions/485261/change-boot-order-using-efibootmgr
From my understanding Windows was referring to its configuration file named shimx64.efi and not to the grub2 file. I therefore ran boot repair to fix any issue related to booting then I went on my windows and performed in Windows Administrator Command Prompt the following line:
bcdedit /set {bootmgr} path \EFI\ubuntu\shimx64.efi
Finally, it fixed the problem. Thanks to all
With these two parameters in your /etc/default/grub:
GRUB_DEFAULT=saved
GRUB_SAVEDEFAULT=true # note the difference
it'll remember the LAST chosen OS. So select Ubuntu, and it'll default to Ubuntu on the next boot.
You must do a sudo update-grub after making changes to /etc/default/grub for this to work.
heynnema
  • 73,649
