-1
I am annoyed trying this but all I am trying to do is set JAVA_HOME in /etc/environment file in Bash shell on Windows which is being offered now with Windows. My local Java is at C:\Program Files\Java\jdk1.8.0_91 so in my /etc/environment I am putting
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
export JAVA_HOME="/mnt/c/Program\ Files/Java/jdk1.8.0_91/"
Read online that to specify a space, one should use \. On doing this:
cd /mnt/c/Program\ Files/Java/jdk1.8.0_91/
I can navigate to directory but on putting the same in /etc/environment file and sourcing it, if I run
echo $JAVA_HOME
I can tell that it is incorrect as it is reading it as \, and which is why doing
cd $JAVA_HOME
fails
Ubuntu 14.04.5 LTS
If someone can please suggest as to how to solve this will be greatly appreciated. Thank you.
terdon
  • 104,119
Don't use export in /etc/environment, it's just a simple file and not a script. It is reading the lines one by one and is setting the variables that way.
Again, it will not run commands.
terdon
  • 104,119
Ziazis
  • 2,184
To use a space in the Linux world you need to do one (and only one) of the following:
  1. Quote all the things:
    JAVA_HOME="/mnt/c/Program Files/Java/jdk1.8.0_91/"
    cd "$JAVA_HOME"
  2. Escape the space:
    JAVA_HOME=/mnt/c/Program\ Files/Java/jdk1.8.0_91/
    cd "$JAVA_HOME"
But not both. The issue here is that quoting protects the quoted string and makes it be interpreted literally. So while foo\ bar means foo, a space and then bar, "foo\ bar" means foo, a backslash, a space and then bar.
Also, whenever you use a variable, you should pretty much always put it inside double quotes otherwise the command you are passing it to will read two arguments. You can see what went wrong if you enable bash debugging by running set -x (run set +x to turn it off):
$ set -x
$ cd $JAVA_HOME
+ cd /mnt/c/Program Files/Java/jdk1.8.0_91/
bash: cd: too many arguments
What you ran was cd /mnt/c/Program Files/Java/jdk1.8.0_91/. Since whitespace separates arguments, this means you passed cd two separate arguments: /mnt/c/Program and Files/Java/jdk1.8.0_91/. Quoting causes cd (or any other tool) to read the whole thing as a single argument.
Further reading:
terdon
  • 104,119
Now, you have to set a JAVA_HOME variable for the environment.
Do the following things:
  1. Find the path where your java is installed. (Most likely in /usr/lib/jvm/{JAVA_VERSION}).
  2. Now on the other terminal, open sudo vi /etc/environment
  3. You have to enter: JAVA_HOME="/usr/lib/jvm/java-9-oracle"
