What is the ideal version for this machine (Intel Atom Cpu D510 1.66GHz Dual Core 32 bits) I think the problem is that the minimum requirement is a 2GHz dual processor. What can be another option?
Both options work and I am sure there will be no major performance differences between 17.04 and 16.04, and the documentation says the same. Although if I were you I would install Lubuntu which is a really lightweight version of Ubuntu with less preinstalled packages. Also you did not mention the amount of memory you had so if it is below 1 gig i would recommend Lubuntu.
It is great for low spec systems like the one above, but Ubuntu regular should work as well.
Here is some documentation to read up on for further questions:
https://help.ubuntu.com/community/Installation/SystemRequirements
All the best
-1
You can find the system requirements at here:
https://www.ubuntu.com/download/desktop
as bellow
