23
Can I mount a zip (or other non-solid (so that accessing a file wouldn't decompress the whole archive) compressed archive format file) as a file system in Ubuntu?
Ivan
  • 58,745
Install the package avfs then execute:
mountavfs
Say you have a zip file in ~/Documents/file.zip, then
cd ~/.avfs/home/$USER/Documents
ls -l file.zip#/
You could also browse the content in Nautilus, but you need to add a trailing # character by hand to the path (Ctrl-L to access the address bar).
enzotib
  • 96,093
In Nautilus, right click on the archive and then click "Open with Archive Mounter", once you've done this, your archive will show up as a new “drive” in Nautilus. (check tutorial here)
fuse-zip is a fuse filesystem, that enables any program to work with a ZIP archive as though it is a plain directory. Unlike KIO or Gnome VFS, it can be used in any application without modifications.
https://github.com/google/mount-zip
Le Droid
  • 121
