I was trying to create 26GB fat32 partition & 6GB ext4 Partition in my new samsung 32Gb sd card by using Gparted.
but gparted ended in error.The last step formatting the partition as fat32 ended as error.
my Micro Sd Card's current status
I tried Gparted , kde partition Manager, fdisk , gdisk , gparted all them can create corrupted GPT or msdos & allowed me to create partition. which didn't last after removing & inserting sd card again
back to level one no partition table
someone please help me to solve the problem thanks in advance for your help
Well I suggest use fdisk again for making partition and then mkfs for making file system . About lable problem I can say that If your partition will going to be a Linux partition so e2lable or tune2fs -L commands can help you change partition label . for making partition flow these steps :
  1. $ fdisk /dev/sdb
  2. then press p for list partition . Then n , p , sector , size . Then press p again if you can see your partition or not . Then use t for changing partition type ( Ext , NTFS , ... ) . Press w to write with ioctl .
  3. $ mkfs.ext3 /dev/sdb1 which make file system on your partition . ( Replace ext3 with any partition type you made ) .
Then you can add partition label with e2label command . see man e2label .
Ali Ghasempour
  • 449
