I'm trying to read my SD cards. They worked fine several times, I wrote some data onto them, then I used them on my cell phone. After that I tried opening them on somebody else's Windows but it wouldn't see them. I came home and tried opening them on my Ubuntu but it says:
Error mounting /dev/sdc1 at /media/yuha/3161-3131: Command-line `mount -t "exfat" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,iocharset=utf8,namecase=0,errors=remount-ro,umask=0077" "/dev/sdc1" "/media/yuha/3161-3131"' exited with non-zero exit status 2:
stdout: `FUSE exfat 1.0.1
stderr: `BUG: failed to read 512 bytes from file at 0.
I tried searching for an answer with this "non-zero exit status 2" but everyone else seems to have status 32.
What can I do to fix this? I don't need the data on SD cards, I just want to be able to use them again. I wanted to format them but it says device not found. How can I reach the cards and format them or otherwise return them to normal state?
Upon trying to check the integrity it gave this:
$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 238.5G 0 disk
├─sda1 8:1 0 100M 0 part
├─sda2 8:2 0 97.7G 0 part
├─sda3 8:3 0 138.8G 0 part /
└─sda4 8:4 0 2G 0 part [SWAP]
sdb 8:16 0 931.5G 0 disk
├─sdb1 8:17 0 244.1G 0 part
└─sdb2 8:18 0 687.4G 0 part /media/data
sr0 11:0 1 1024M 0 rom
$ ls -l /dev/disk/by-id
total 0
lrwxrwxrwx 1 root root 9 Aug 11 20:25 ata-MATSHITABD-CMB_UJ160_WR39_009484 -> ../../sr0
lrwxrwxrwx 1 root root 9 Aug 11 20:25 ata-TOSHIBA_THNSNJ256GMCU_34NS101OT4ZW -> ../../sda
lrwxrwxrwx 1 root root 10 Aug 11 20:25 ata-TOSHIBA_THNSNJ256GMCU_34NS101OT4ZW-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 Aug 11 20:25 ata-TOSHIBA_THNSNJ256GMCU_34NS101OT4ZW-part2 -> ../../sda2
lrwxrwxrwx 1 root root 10 Aug 11 20:25 ata-TOSHIBA_THNSNJ256GMCU_34NS101OT4ZW-part3 -> ../../sda3
lrwxrwxrwx 1 root root 10 Aug 11 20:25 ata-TOSHIBA_THNSNJ256GMCU_34NS101OT4ZW-part4 -> ../../sda4
lrwxrwxrwx 1 root root 9 Aug 11 20:25 ata-WDC_WD10EZEX-21M2NA0_WCC3F5RZDVUH -> ../../sdb
lrwxrwxrwx 1 root root 10 Aug 11 20:25 ata-WDC_WD10EZEX-21M2NA0_WCC3F5RZDVUH-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 10 Aug 11 20:25 ata-WDC_WD10EZEX-21M2NA0_WCC3F5RZDVUH-part2 -> ../../sdb2
lrwxrwxrwx 1 root root 9 Aug 14 12:14 usb-Mass_Storage_Device_121220160204-0:0 -> ../../sdc
lrwxrwxrwx 1 root root 9 Aug 11 20:25 wwn-0x500080d9100e53ba -> ../../sda
lrwxrwxrwx 1 root root 10 Aug 11 20:25 wwn-0x500080d9100e53ba-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 Aug 11 20:25 wwn-0x500080d9100e53ba-part2 -> ../../sda2
lrwxrwxrwx 1 root root 10 Aug 11 20:25 wwn-0x500080d9100e53ba-part3 -> ../../sda3
lrwxrwxrwx 1 root root 10 Aug 11 20:25 wwn-0x500080d9100e53ba-part4 -> ../../sda4
lrwxrwxrwx 1 root root 9 Aug 11 20:25 wwn-0x50014ee26056824c -> ../../sdb
lrwxrwxrwx 1 root root 10 Aug 11 20:25 wwn-0x50014ee26056824c-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 10 Aug 11 20:25 wwn-0x50014ee26056824c-part2 -> ../../sdb2
$ sudo dd if=/dev/sdc of=/dev/null count=1
[sudo] password for yuha:
dd: failed to open ‘/dev/sdc’: No medium found
So it cannot see the sdc upon lsblk command but can see it upon the other one. However, it says "no medium" if I try to access it. I tried dmesg, it gave a lot of information, I am pasting some here:
[211738.615775] scsi 10:0:0:0: Direct-Access Mass Storage Device 1.00 PQ: 0 ANSI: 0 CCS
[211738.616627] sd 10:0:0:0: Attached scsi generic sg3 type 0
[211739.010981] sd 10:0:0:0: [sdc] 123992064 512-byte logical blocks: (63.4 GB/59.1 GiB)
[211739.011231] sd 10:0:0:0: [sdc] Write Protect is off
[211739.011241] sd 10:0:0:0: [sdc] Mode Sense: 03 00 00 00
[211739.011482] sd 10:0:0:0: [sdc] No Caching mode page found
[211739.011492] sd 10:0:0:0: [sdc] Assuming drive cache: write through
[211739.014185] sdc: sdc1
[211739.015282] sd 10:0:0:0: [sdc] Attached SCSI removable disk
[211743.676940] sdc: detected capacity change from 63483936768 to 0
[211768.444125] usb 3-10: USB disconnect, device number 8
[211771.434907] usb 3-8: new high-speed USB device number 9 using xhci_hcd
[211771.564119] usb 3-8: New USB device found, idVendor=14cd, idProduct=1212
[211771.564127] usb 3-8: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[211771.564131] usb 3-8: Product: Mass Storage Device
[211771.564134] usb 3-8: Manufacturer: Generic
[211771.564137] usb 3-8: SerialNumber: 121220160204
[211771.564800] usb-storage 3-8:1.0: USB Mass Storage device detected
[211771.565089] scsi11 : usb-storage 3-8:1.0
[211772.563279] scsi 11:0:0:0: Direct-Access Mass Storage Device 1.00 PQ: 0 ANSI: 0 CCS
[211772.563936] sd 11:0:0:0: Attached scsi generic sg3 type 0
[211772.958456] sd 11:0:0:0: [sdc] 123992064 512-byte logical blocks: (63.4 GB/59.1 GiB)
[214266.173071] Buffer I/O error on device sdc1, logical block 4104
[214266.173071] Buffer I/O error on device sdc1, logical block 4105
[214266.173461] sd 18:0:0:0: [sdc]
[214266.173463] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[214266.173464] sd 18:0:0:0: [sdc]
[214266.173465] Sense Key : Medium Error [current]
[214266.173466] sd 18:0:0:0: [sdc]
[214266.173467] Add. Sense: Unrecovered read error
[214266.173468] sd 18:0:0:0: [sdc] CDB:
[214266.173468] Read(10): 28 00 00 01 00 00 00 00 08 00
[214266.173471] end_request: critical medium error, dev sdc, sector 65536
[214266.254724] sdc: detected capacity change from 127865454592 to 0
[214312.436215] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null)
