When I used Ubuntu 10.10, my tvtime worked perfectly. After upgrading to Ubuntu 11.10, it only shows "no signal". I've searched throughout the internet for a whole day and couldn't fix it. I also use Windows XP at the same time and it works.
Here is my specification.
- Ubuntu 11.10.
- Pinnacle PCTV Hybrid Pro PCI 310i (Philips saa7134)
- tvtime 1.0.2-6ubuntu1 (I downgraded from 1.0.2-7ubuntu1, default by Ubuntu 10.10)
I'm in Germany which means: PAL/PAL-BG and Frequency table=europe
Here is for the information:
$ lspci 00:1b.0 Audio device: Intel Corporation N10/ICH 7 Family High Definition Audio Controller (rev 01) 01:01.0 Multimedia controller: Philips Semiconductors SAA7131/SAA7133/SAA7135 Video Broadcast Decoder (rev d1) 04:00.1 Audio device: Advanced Micro Devices [AMD] nee ATI RV620 HDMI Audio [Radeon HD 3400 Series]
$ cat /proc/asound/cards
 0 [Intel          ]: HDA-Intel - HDA Intel
                      HDA Intel at 0xdfcf8000 irq 43
 1 [HDMI           ]: HDA-Intel - HDA ATI HDMI
                      HDA ATI HDMI at 0xdfffc000 irq 44
 2 [SAA7134        ]: SAA7134 - SAA7134
                      saa7133[0] at 0xdfdff800 irq 21
$ xawtv -hwscan
This is xawtv-3.95.dfsg.1, running on Linux/i686 (3.0.0-14-generic)
looking for available devices
port 143-146
    type : Xvideo, image scaler
    name : ATI Radeon AVIVO Video
/dev/video0: OK                         [ -device /dev/video0 ]
    type : v4l2
    name : Pinnacle PCTV 310i
    flags: overlay capture tuner
$ dmesg | grep saa [ 4.484856] saa7130/34: v4l2 driver version 0.2.16 loaded [ 4.484918] saa7134 0000:01:01.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21 [ 4.484924] saa7133[0]: found at 0000:01:01.0, rev: 209, irq: 21, latency: 64, mmio: 0xdfdff800 [ 4.484931] saa7133[0]: subsystem: 11bd:002f, board: Pinnacle PCTV 310i [card=101,insmod option] ... [ 4.889137] saa7133[0]: registered device video0 [v4l2] [ 4.889169] saa7133[0]: registered device vbi0 [ 4.889199] saa7133[0]: registered device radio0 [ 4.933671] saa7134 ALSA driver for DMA sound loaded [ 4.933836] saa7133[0]/alsa: saa7133[0] at 0xdfdff800 irq 21 registered as card -2 [ 4.980908] DVB: registering new adapter (saa7133[0])
$ dmesg | grep tuner [ 4.730294] i2c-core: driver [tuner] using legacy suspend method [ 4.730298] i2c-core: driver [tuner] using legacy resume method [ 4.824208] tuner 0-004b: Tuner -1 found with type(s) Radio TV. [ 4.856615] tuner-simple 0-004b: creating new instance [ 4.856620] tuner-simple 0-004b: type set to 61 (Tena TNF9533-D/IF/TNF9533-B/DF)
So my card=101 and tuner=61, then tried to use rmmod and load it back with modprobe and it still shows "no signal".
$ modprobe saa7134 card=101 tuner=61
And if I run tvtime with verbose setting, it will show:
$ sudo tvtime -v Running tvtime 1.0.2. Reading configuration from /etc/tvtime/tvtime.xml Reading configuration from /home/winnuayi/.tvtime/tvtime.xml cpuinfo: CPU Intel(R) Core(TM)2 Duo CPU E4500 @ 2.20GHz, family 6, model 15, stepping 13. cpuinfo: CPU measured at 2200.051MHz. xcommon: Display :0.0, vendor The X.Org Foundation, vendor release 11004000 xfullscreen: Using XINERAMA for dual-head information. xfullscreen: Pixels are square. xfullscreen: Number of displays is 2. xfullscreen: Head 0 at 0,0 with size 1680x1050. xfullscreen: Head 1 at 1680,0 with size 1680x1050. xcommon: Have XTest, will use it to ping the screensaver. xcommon: Pixel aspect ratio 1:1. xcommon: Pixel aspect ratio 1:1. xcommon: Window manager is Metacity and is EWMH compliant. xcommon: You are using metacity. Disabling aspect ratio hints xcommon: since most deployed versions of metacity are still broken. xcommon: Using EWMH state fullscreen property. xcommon: Using EWMH state above property. xcommon: Using EWMH state below property. xcommon: Pixel aspect ratio 1:1. xcommon: Displaying in a 768x576 window inside 768x576 space. xvoutput: Using XVIDEO adaptor 143: ATI Radeon AVIVO Video. speedycode: Using MMXEXT optimized functions. station: Reading stationlist from /home/winnuayi/.tvtime/stationlist.xml videoinput: Using video4linux2 driver 'saa7134', card 'Pinnacle PCTV 310i' (bus PCI:0000:01:01.0). videoinput: Version is 528, capabilities 5010015. videoinput: Maximum input width: 720 pixels. tvtime: Sampling input at 720 pixels per scanline. xcommon: Pixel aspect ratio 1:1. xcommon: Displaying in a 768x576 window inside 768x576 space. xcommon: Received a map, marking window as visible (59). xcommon: Pixel aspect ratio 1:1. xcommon: Displaying in a 768x576 window inside 768x576 space.
Using $ scantv -C/dev/vbi0, no signal could be detected.
Everything looks fine. alsamixer is also fine. I don't know where the problem is. I'll appreciate anyone who can show some hints. :)
