I would like to install the libdevicemapper and brtfs header files on my 16.04:
$ apt-cache search libdevmapper-dev
libdevmapper-dev - Linux Kernel Device Mapper header files
$ sudo apt-get install libdevmapper-dev
Reading package lists... Done
Building dependency tree
libdevmapper-dev : Depends: libudev-dev but it is not going to be installed
So I tried:
$ sudo apt-get install libudev-dev
libudev-dev : Depends: libudev1 (= 229-4ubuntu4) but 229-4ubuntu13 is to be installed
And then:
$ sudo apt-get install -f libudev1
libudev1 is already the newest version (229-4ubuntu13).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I can't find brtfs at all.
