I am attempting to UEFI secure boot boot from a new installation of Ubuntu 17.04 desktop. UEFI is reporting that there is no bootable disk on the system or that the boot disk is damaged.
Hardware Configuration
  • HP Pavillion P7-1080la 16GB memory
  • Processor: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
  • /dev/sda KINGSTON SVP200S3120G (501ABBF0) 120GB SSD
  • /dev/sdb WDC WD20EARS-60MVWB0 (51.0AB51) 2.0TB
Partitioning using GPT
/dev/sda1 ESD Partition 400MiB
/dev/sda2 System Partition 25GiB
/dev/sda3 Home Partition 90GiB
/dev/sda is zeroed before installation with dd the partition table is created with gdisk and the partitions are created with gparted.
/dev/sdb is not used during installation.
Installation
Installation is performed using the "other" option for partitioning and the root directory / is assigned to /dev/sda2. Installation is then performed normally.
Troubleshooting
Installation is performed normally and on reboot I enter the BIOS to verify the boot order. The entry from BOOT000 named ubuntu shows up as the only UEFI boot drive. However when I let the boot proceed UEFI reports that there is no boot drive or that the drive is damaged.
When I reboot using a LiveUsb I invoke the disk check option from the Grub2 menu and it reports a clean bill of health.
After reboot I check /dev/sda1 with fsck.fat and /dev/sda2 with fsck.ext4 and both report everything OK. I then run the "verify" option in gdisk and it also reports everything OK. I have run boot-repair with the option to produce a report which can be found at https://pastebin.com/rKbrBe8j.
I have tried 3 flavors of Ubuntu with the same result:
  • Ubuntu 17.04 Desktop 64 bit
  • Ubuntu 16.04 Desktop 64 bit
  • Ubuntu-Gnome 16.04.3 Desktop 64 bit
I have also tried a system installation using LVM as well as a normal installation. I have tried with a separate boot partition and with a normal system partition.
I have also tried running the recommended repair operation with boot-repair.
This system has been running Ubuntu since early 2012 without problems up to two weeks ago. It will boot from either of two UEFI pendrives, one created as a GPT UEFI system and the other a standard legacy BIOS boot pendrive.
From what I can see I have one of two problems:
  • There is something wrong with the installed system that is confusing the first stage Grub2 loader shimx64.efi. However no diagnostics of any kind are issued.
  • UEFI has a problem handling something in the system layout.
  • UEFI has a bug.
I bought this machine in Feb. 2012 so it has a very early version of the UEFI firmware. For example it has no way to disable secure boot. It originally came with Windows 8 pre-installed and I ran it dual booted for a while before getting rid of Windows.
Based on a comment I have tried the following three suggestions
  • Added a "Windows Boot Manager" EFI boot entry pointing to ubuntu/shimx64.efi.
  • Created a EFI/boot directory on the ESD with a copy of the EFI/ubuntu directory.
  • Installed Refind.
Unfortunately none of these suggestions made the boot volume visible.
I followed Rod Smith's suggestion to use the advanced repair capabilities of boot-repair but I got the same result as always. Unable to find a boot volume. The bootinfo log is at https://pastebin.com/xRJBb5kx.
What should be my next troubleshooting steps as I have tried everything I know of?
Jonathan
  • 1,498
