I have recently been trying to install Shutter and I get This error when I type sudo apt-get install shutter
Reading package lists... Done
Building dependency tree
 shutter : Depends: libgnome2-perl but it is not going to be installed
           Depends: libgnome2-vfs-perl but it is not going to be installed
           Depends: libgnome2-wnck-perl but it is not going to be installed
           Depends: libgnome2-gconf-perl but it is not going to be installed
           Depends: libxml-simple-perl but it is not going to be installed
           Depends: libwww-mechanize-perl but it is not going to be installed
           Depends: libwww-perl but it is not going to be installed
           Depends: perlmagick
           Depends: libgtk2-imageview-perl but it is not going to be installed
           Depends: libnet-dbus-perl but it is not going to be installed
           Depends: libgnome2-canvas-perl but it is not going to be installed
           Depends: libgtk2-unique-perl but it is not going to be installed
           Depends: libproc-processtable-perl but it is not going to be installed
           Depends: libjson-xs-perl but it is not going to be installed
           Depends: libnet-dropbox-api-perl but it is not going to be installed
           Recommends: libgoo-canvas-perl but it is not going to be installed
           Recommends: libgtk2-appindicator-perl but it is not going to be installed
Byte Commander
  • 110,243
I came about this solution because for this game, scrabble AI, a standalone scrabble game, I needed sudo apt install libgnome2-canvas-perl, which did not work.
however, this page to install shutter using a ppa got it for me and the game now works.
sudo add-apt-repository ppa:linuxuprising/shutter
sudo apt update
sudo apt update shutter
shutter does open up after installing some plugin updates. I then removed the ppa from software sources, just to be cautious.
edit: oops forgot the most important thing (for me) the scrabble game https://github.com/apikler/ScrabbleAI
unzip, run perl scrabble.pl from where you put it.
pierrely
  • 725
