Having some problems with Filezilla crashing/closing itself unexpectedly whenever I try to perform an action on a (sftp) remote server, whether that's changing directories, uploading, or downloading a file. It connects just fine, and I can navigate local directories with no problem, but when I try to do anything on any remote server the whole thing shuts down.
The version is Filezilla v3.21.0, compiled for x86_64-pc-linux-gnu, running on Ubuntu 16.04 LTS 64-bit. The Filezilla log files aren't very enlightening:
2017-08-10 14:41:23 4088 1 Status: Connecting to grantshop.ca... 2017-08-10 14:41:23 4088 1 Response: fzSftp started, protocol_version=6 2017-08-10 14:41:23 4088 1 Command: open "grants@grantshop.ca" 22 2017-08-10 14:41:23 4088 1 Command: Pass: ******** 2017-08-10 14:41:23 4088 1 Status: Connected to grantshop.ca 2017-08-10 14:41:23 4088 1 Status: Retrieving directory listing... 2017-08-10 14:41:23 4088 1 Command: pwd 2017-08-10 14:41:23 4088 1 Response: Current directory is: "/home/grants" 2017-08-10 14:41:23 4088 1 Command: ls 2017-08-10 14:41:23 4088 1 Status: Listing directory /home/grants 2017-08-10 14:41:24 4088 1 Status: Directory listing of "/home/grants" successful 2017-08-10 14:42:40 4088 1 Status: Retrieving directory listing of "/home/grants/grantshop.ca"...
Uploading/downloading produces similar logs, where the last log line is 7088 3 Status: Starting download of /home/grants/something.txt or something similar.
Running Filezilla from the terminal gets me this:
Reading locale option from /home/user/.filezilla/filezilla.xml 03:36:32 PM: Debug: Failed to connect to session manager: SESSION_MANAGER environment variable not defined wxD-Bus: Signal from /org/freedesktop/DBus, member NameAcquired wxD-Bus: Reply with serial 2 wxD-Bus: Reply to RegisterClient, our object path is /org/gnome/SessionManager/Client27 wxD-Bus: CPowerManagementInhibitor: Requesting busy wxD-Bus: Reply with serial 3 wxD-Bus: Reply: Error: The name org.freedesktop.PowerManagement was not provided by any .service files wxD-Bus: Falling back to org.gnome.SessionManager wxD-Bus: CPowerManagementInhibitor: Requesting busy wxD-Bus: Reply with serial 4 wxD-Bus: CPowerManagementInhibitor: Request successful, cookie is 1943892549 wxD-Bus: CPowerManagementInhibitor: Requesting idle wxD-Bus: Reply with serial 5 wxD-Bus: CPowerManagementInhibitor: Request successful wxD-Bus: CPowerManagementInhibitor: Requesting busy filezilla: symbol lookup error: filezilla: undefined symbol: _ZN2fz18replace_substringsERKNSt7__cxx1112basic_stringIwSt11char_traitsIwESaIwEEES7_S7_
