After allocating my system (Ubuntu 16.04) in data center, suddenly my Genymotion stopped working by following error:
Logging activities to file: /home/*/.Genymobile/genymotion.log (noting logged here)
Segmentation fault (core dumped)
So I re-install it, but still same problem.... So I checked the Virtualbox by following:
$ sudo /etc/init.d/vboxdrv status
sudo: /etc/init.d/vboxdrv: command not found
So I came up with uninstalling both and installing them again. but the problem is still exists
Here is what I have done:
installing Virtualbox and related package:
$ sudo dpkg -i virtualbox-5.1_5.1.16-1138411~Ubuntu~xenial_amd64.deb (downloaded from virtualbox.org)
Selecting previously unselected package virtualbox-5.1.
(Reading database ... 246386 files and directories currently installed.)
Preparing to unpack virtualbox-5.1_5.1.16-113841~Ubuntu~xenial_amd64.deb ...
Unpacking virtualbox-5.1 (5.1.16-113841~Ubuntu~xenial) ...
Setting up virtualbox-5.1 (5.1.16-113841~Ubuntu~xenial) ...
addgroup: The group `vboxusers' already exists as a system group. Exiting.
Processing triggers for systemd (229-4ubuntu17) ...
Processing triggers for ureadahead (0.100.0-19) ...
Processing triggers for hicolor-icon-theme (0.15-0ubuntu1) ...
Processing triggers for shared-mime-info (1.5-2ubuntu0.1) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu5.1) ...
Processing triggers for gnome-menus (3.13.3-6ubuntu3.1) ...
Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20160824-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for mime-support (3.59ubuntu1) ...
$ sudo apt-get install -f
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 162 not upgraded.
$ sudo apt-get install dkms
The following NEW packages will be installed:
  dkms
0 upgraded, 1 newly installed, 0 to remove and 162 not upgraded.
Need to get 0 B/66.1 kB of archives.
After this operation, 265 kB of additional disk space will be used.
Selecting previously unselected package dkms.
(Reading database ... 247164 files and directories currently installed.)
Preparing to unpack .../dkms_2.2.0.3-2ubuntu11.3_all.deb ...
Unpacking dkms (2.2.0.3-2ubuntu11.3) ...
Processing triggers for man-db (2.7.5-1) ...
Setting up dkms (2.2.0.3-2ubuntu11.3) ...
$ sudo /usr/src/linux-headers-$(uname -r)/s
scripts/sign-file sha256 ./MOK.priv ./MOK.der $(modinfo -n vboxdrv)
$ sudo apt-get install linux-headers-`uname -r`
linux-headers-4.10.0-30-generic is already the newest version (4.10.0-30.34~16.04.1).
Install and run Genymotion:
$ ./genymotion-2.8.1_x64.bin -d /opt/
    Installing for all users.
    Installing to folder [/opt/genymotion]. Are you sure [y/n] ? y
    - Trying to find VirtualBox toolset .................... OK (Valid version of VirtualBox found: 5.1.16r113841)
    - Extracting files ..................................... OK (Extract into: [/opt/genymotion])
    - Installing launcher icon ............................. OK
    Installation done successfully.
    You can now use these tools from [/opt/genymotion]:
     - genymotion
     - genymotion-shell
     - gmtool
$ /opt/genymotion/genymotion
I have tried following, but the error still is available:
$ sudo apt-get install build-essential module-assistant
build-essential is already the newest version (12.1ubuntu2).
module-assistant is already the newest version (0.11.8).
$ sudo m-a prepare
Getting source for kernel version: 4.10.0-30-generic
Kernel headers available in /usr/src/linux-headers-4.10.0-30-generic
Creating symlink...
Done!
$ sudo /etc/init.d/vboxdrv setup
here is the result of /etc/init.d/virtualbox status:
virtualbox.service - LSB: VirtualBox Linux kernel module
   Loaded: loaded (/etc/init.d/virtualbox; bad; vendor preset: enabled)
   Active: failed (Result: exit-code) since Wed 2017-08-09 23:51:09 IRDT; 12h ago
     Docs: man:systemd-sysv-generator(8)
Aug 09 23:51:09 *-G31M-ES2C virtualbox[31835]:  * Loading VirtualBox kern...
Aug 09 23:51:09 *-G31M-ES2C virtualbox[31835]:  * No suitable module for ...
Aug 09 23:51:09 *-G31M-ES2C virtualbox[31835]:    ...fail!
Aug 09 23:51:09 *-G31M-ES2C systemd[1]: virtualbox.service: Control proc...1
Aug 09 23:51:09 *-G31M-ES2C systemd[1]: Failed to start LSB: VirtualBox ....
Aug 09 23:51:09 *-G31M-ES2C systemd[1]: virtualbox.service: Unit entered....
Aug 09 23:51:09 *-G31M-ES2C systemd[1]: virtualbox.service: Failed with ....
Aug 10 00:04:22 *-G31M-ES2C systemd[1]: Stopped LSB: VirtualBox Linux ke....
Aug 10 00:08:51 *-G31M-ES2C systemd[1]: Stopped LSB: VirtualBox Linux ke....
Aug 10 00:23:30 *-G31M-ES2C systemd[1]: Stopped LSB: VirtualBox Linux ke....
Hint: Some lines were ellipsized, use -l to show in full.
I just reboot the system and here is the result again:
$ sudo /etc/init.d/virtualbox status
● virtualbox.service - LSB: VirtualBox Linux kernel module
   Active: active (exited) since Thu 2017-08-10 12:15:37 IRDT; 4min 14s ago
  Process: 1107 ExecStart=/etc/init.d/virtualbox start (code=exited, status=0/SUCCESS)
Aug 10 12:15:37 *-G31M-ES2C systemd[1]: Starting LSB: VirtualBox Linux k....
Aug 10 12:15:37 *-G31M-ES2C systemd[1]: Started LSB: VirtualBox Linux ke....
$ opt/genymotion/genymotion
Logging activities to file: /home/*/.Genymobile/genymotion.log (still empty)
I found That following command is same as /etc/init.d/vboxdrv setup|status (reference)
 /sbin/rcvboxdrv setup|status
here is the result:
VirtualBox kernel modules (vboxdrv, vboxnetflt, vboxnetadp, vboxpci) are loaded
I also try solution in Problem with running genymotion in KDE desktop but I get following error:
    Aborted (core dumped)
and here is the *.log file:
Aug 11 01:40:08 [genymotion] [fatal] This application failed to start because it could not find or load the Qt platform plugin "xcb".
Reinstalling the application may fix this problem.
Also I check library needed by Qt as stated in here, but noting listed in result, so all necessary lib is available.
Edit 1
I find that system with systemd dumped core to /var/lib/systemd/coredump/ so first I install coredumpctl and then run Genymotion to create core dump. Follow instruction here to create dump.core, here is the result:
$ coredumpctl dump 9808 --output /home/*/genymotion.core
    PID: 9808(genymotion)
           UID: 1000 (*)
           GID: 1000 (*)
        Signal: 6 (ABRT)
     Timestamp: Fri 2017-08-11 12:37:29 IRDT (4min 58s ago)
  Command Line: /opt/genymotion/genymotion
    Executable: /opt/genymotion/genymotion
 Control Group: /user.slice/user-1000.slice/session-c2.scope
          Unit: session-c2.scope
         Slice: user-1000.slice
       Session: c2
     Owner UID: 1000 (*)
       Boot ID: f572250f03be48d9aa9facf22d0ffd0a
    Machine ID: *******
      Hostname: *-G31M-ES2C
      Coredump: /var/lib/systemd/coredump/core.genymotion.1000.f572250f03be48d9aa9facf22d0ffd0a.9808.1502438849000000000000.xz
       Message: Process 9808 (genymotion) of user 1000 dumped core.
                Stack trace of thread 9808:
                #0  0x00007f86f96c2428 __GI_raise (libc.so.6)
                #1  0x00007f86f96c402a __GI_abort (libc.so.6)
                #2  0x00000000004b6fb7 n/a (genymotion)
                #3  0x00007f86fa74f468 n/a (libQt5Core.so.5)
                #4  0x00007f86fa750f69 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5)
                #5  0x00007f86fac80e99 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5)
                #6  0x00007f86fac80ecd _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5)
                #7  0x00007f86fa9487e6 _ZN16QCoreApplication4initEv (libQt5Core.so.5)
                #8  0x00007f86fa948856 _ZN16QCoreApplicationC1ER23QCoreApplicationPrivate (libQt5Core.so.5)
                #9  0x00007f86fac82cc9 _ZN15QGuiApplicationC1ER22QGuiApplicationPrivate (libQt5Gui.so.5)
                #10 0x00007f86fa18ebcd _ZN12QApplicationC2ERiPPci (libQt5Widgets.so.5)
                #11 0x0000000000438c53 n/a (genymotion)
                #12 0x000000000042373e n/a (genymotion)
                #13 0x00007f86f96ad830 __libc_start_main (libc.so.6)
                #14 0x0000000000429739 n/a (genymotion)
More than one entry matches, ignoring rest.
and then run folllowing as @kenorb said:
$ gdb -c genymotion.core
GNU gdb (Ubuntu 7.11.1-0ubuntu1~16.5) 7.11.1
Copyright (C) 2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word".
[New LWP 9808]
Core was generated by `/opt/genymotion/genymotion'.
Program terminated with signal SIGABRT, Aborted.
#0  0x00007f86f96c2428 in ?? ()
(gdb) bt
#1  0x00007f86f96c402a in ?? ()
#2  0x0000000000000020 in ?? ()
#3  0x0000000000000000 in ?? ()
(gdb) bt full
No symbol table info available.
Edit 2
I have remove builtin qt in Genymotion, and check available qt in my system:
$ qtchooser -list-versions
default
qt4-x86_64-linux-gnu
qt4
qt5-x86_64-linux-gnu
qt5
but it still failed to start Genymotion.
I also install qt-5.9.1 by downloading qt-unified-linux-x64-3.0.0-online from here but it doesn't list when I run qtchooser -list-versions. (no newer version was available), how should I force Genymotion work with this?
Edit 3
The solution didn't work for me I came up with reinstalling the operating system. Now all the thing is ok. but After rebooting system Genymotion failed again.
Your crash seems to be related to Qt framework (libQt5Gui.so.5). These are the revelant lines:
Searching for _ZNK14QMessageLogger5fatalEPKcz gives some similar issues with this library.
Please see the following bug:
which suggest this problem happens in Qt 5.5.1-9, however not in 5.5.1-7 (or -8). So you could try to upgrade or downgrade your Qt.
Another workaround to try is to remove /var/lib/sddm/.cache file as per this comment.
Ideally if you could upgrade your Qt to the latest available version, otherwise try to install it manually (5.9.2 or above) in order to replace your faulty libQt5Gui.so.5 file library, or build from the source code.
kenorb
  • 10,944
