I recently ran into a problem with discord updating and I want to uninstall it via command line to reinstall it, but I dont know how. would anyone know how to do that?
Connor
  • 91
The .deb install on discord's website installs a package named "discord" try running
sudo apt-get remove discord
in your terminal. Then reinstall it the same way you installed it in the first place. I don't know if this will work if you installed it a diffirent way.
Edit: I also previously got the discord message to update this afternoon, and ran the command and used this file to update discord: Discord .deb install from discordapp.com
Evan
  • 111
In ubuntu 18.04 discord can be easily installed, removed with snap:
sudo snap remove discord
sudo snap install discord
