I'm tring to run
sudo apt-get -f install
Output:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
linux-headers-4.4.0-53 linux-headers-4.4.0-53-generic linux-headers-4.4.0-57 linux-headers-4.4.0-57-generic linux-headers-4.4.0-59 linux-headers-4.4.0-59-generic linux-headers-4.4.0-62 linux-headers-4.4.0-62-generic
linux-headers-4.4.0-63 linux-headers-4.4.0-63-generic linux-headers-4.4.0-64 linux-headers-4.4.0-64-generic linux-headers-4.4.0-66 linux-headers-4.4.0-66-generic linux-headers-4.4.0-70 linux-headers-4.4.0-70-generic
linux-headers-4.4.0-71 linux-headers-4.4.0-71-generic linux-headers-4.4.0-72 linux-headers-4.4.0-72-generic linux-headers-4.4.0-75 linux-headers-4.4.0-75-generic linux-headers-4.4.0-78 linux-headers-4.4.0-78-generic
linux-headers-4.4.0-79 linux-headers-4.4.0-79-generic linux-headers-4.4.0-81 linux-headers-4.4.0-81-generic linux-headers-4.4.0-83 linux-headers-4.4.0-83-generic
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
linux-headers-4.4.0-89
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 85 not upgraded.
6 not fully installed or removed.
Need to get 9,919 kB of archives.
After this operation, 70.6 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://eu-central-1.ec2.archive.ubuntu.com/ubuntu xenial-updates/main amd64 linux-headers-4.4.0-89 all 4.4.0-89.112 [9,919 kB]
Fetched 9,919 kB in 0s (23.4 MB/s)
(Reading database ... 467324 files and directories currently installed.)
Preparing to unpack .../linux-headers-4.4.0-89_4.4.0-89.112_all.deb ...
Unpacking linux-headers-4.4.0-89 (4.4.0-89.112) ...
dpkg: error processing archive /var/cache/apt/archives/linux-headers-4.4.0-89_4.4.0-89.112_all.deb (--unpack):
unable to create '/usr/src/linux-headers-4.4.0-89/arch/frv/include/asm/switch_to.h.dpkg-new' (while processing './usr/src/linux-headers-4.4.0-89/arch/frv/include/asm/switch_to.h'): No space left on device
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
The output of dpkg -l | grep linux-image is:
ii linux-image-4.4.0-87-generic 4.4.0-87.110 amd64 Linux kernel image for version 4.4.0 on 64 bit x86 SMP
iF linux-image-4.4.0-89-generic 4.4.0-89.112 amd64 Linux kernel image for version 4.4.0 on 64 bit x86 SMP
iU linux-image-virtual 4.4.0.89.95 amd64 This package will always depend on the latest minimal generic kernel image.
It seems as if Im currently using version .87 with version .89 half way configured (Status iF)
EDIT:
hard disk space is not the issue, output of df -h is:
Filesystem Size Used Avail Use% Mounted on
/dev/root 7.8G 4.9G 2.5G 67% /
devtmpfs 494M 0 494M 0% /dev
tmpfs 496M 4.0K 496M 1% /dev/shm
tmpfs 496M 6.9M 489M 2% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 496M 0 496M 0% /sys/fs/cgroup
tmpfs 100M 0 100M 0% /run/user/1001
/dev/xvdf 7.8G 153M 7.2G 3% /database
