I am not able to install node-v8.2.1-linux-x64.tar.xz in my Ubuntu 16.04.
I am installing node via source - I do not want an apt solution as per:
How to install NodeJS 4 using apt?
Message I am getting:-
npm WARN saveError ENOENT: no such file or directory, open
'/home/ubuntuser/Downloads/node-v8.2.1-linux-x64/lib/package.json'
npm WARN enoent ENOENT: no such file or directory, open
'/home/vishnu/Downloads/node-v8.2.1-linux-x64/lib/package.json'
npm WARN lib No description
npm WARN lib No repository field.
npm WARN lib No README data
npm WARN lib No license field.
Can anybody post the step by step installation process?
fossfreedom
  • 174,526
mevr
  • 133
You can use nvm - node version manager:
curl -o- https://raw.githubusercontent.com/creationix/nvm/v0.33.2/install.sh | bash
nvm install v8.2.1
Test with node -v :)
ponsfrilus
  • 596
  • 17
I created below bash script to install nodejs ... no need to wait for nvm to make latest release available ... cat install_node.sh
#!/bin/bash
# ............... top of cut  ........................  install_node.sh
# export NODE_VER=v8.0.0 # matches meteor 1.4.2.3 # edit this line next time you need to update nodejs
export NODE_VER=v8.2.1
# pick parent dir of nodejs install  ... comment out or remove ONE of below
# export CODE_PARENT_DIR=/opt/code  # root owned dir ... requires you to sudo prior to npm install going forward
export CODE_PARENT_DIR=${HOME}    # RECOMMENDED
# ......... following env vars are OK no edits needed
curr_OS=$( uname )
echo curr_OS $curr_OS
if [[ "${curr_OS}" == "Darwin" ]]; then
    export OS_ARCH=darwin-x64
elif [[ "${curr_OS}" == "Linux" ]]; then
    export OS_ARCH=linux-x64
else
    echo "ERROR - failed to recognize OS $curr_OS"
    exit 5
fi
if [[ -z ${CODE_PARENT_DIR} ]]; then
    echo "ERROR - failed to see env var CODE_PARENT_DIR"
    exit 5
fi
export NODE_CODEDIR=${CODE_PARENT_DIR}/nodejs
export COMSUFFIX=tar.gz
export NODE_NAME=node-${NODE_VER}
export NODE_PARENT=${NODE_CODEDIR}/${NODE_NAME}-${OS_ARCH}
export PATH=${NODE_PARENT}/bin:${PATH}
export NODE_PATH=${NODE_PARENT}/lib/node_modules
# ............... end of cut  ........................  install_node.sh
# put all above export lines into  ~/.bashrc file
echo
echo "NODE_CODEDIR $NODE_CODEDIR<--"
echo
echo "mkdir -p ${NODE_CODEDIR}"
echo
echo
echo "cd ${NODE_CODEDIR}"
      cd ${NODE_CODEDIR}
echo
# this is compiled code NOT source
[ -f ${NODE_NAME}-${OS_ARCH}.${COMSUFFIX} ] && rm ${NODE_NAME}-${OS_ARCH}.${COMSUFFIX} # if file exists remove
echo "wget -q --show-progress https://nodejs.org/download/release/${NODE_VER}/${NODE_NAME}-${OS_ARCH}.${COMSUFFIX}"
echo
echo "tar -C ${NODE_CODEDIR} -xf ${NODE_NAME}-${OS_ARCH}.${COMSUFFIX}"
echo
# ...........  done ........... #
which node
node --version
derHugo
  • 3,376
  • 34
  • 52
