The WiFi symbol on the top right is empty and no WiFi networks appear, I try to set one up but the "device" box is greyed out. I have Ubuntu 16.04. When I enter the command lswh -C network I get this:
*-network UNCLAIMED
description: Network controller
product: BCM43142 802.11b/g/n
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:03:00.0
version: 01
width: 64 bits
clock: 33Mhz
capabilities: cap_list
configuration: latency=0
resources: memory:94100000-94107fff
*-network
description: Ethernet interface
product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
 vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info pci@0000:04:00.0
 logical name: eno1
version: 0a
serial: dc:4a:3e:f7:23:64
capacity: 100Mbiy/s
width: 64 bits
clock: 33Mhz
capabilities: bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8107e-2_0.02 02/26/15 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:129 ioport:3000(size=256) memory:94004000-94004fff memory:94000000-94003fff
And a warning about not running this as super-user
I can access the internet if I use an Ethernet cable, or If I startup the laptop in windows 10
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
You're probably missing the WiFi driver. Open up a terminal and type:
sudo apt-get update
sudo apt-get install bcmwl-kernel-source
EDIT
Disabling secure boot in your BIOS is also necessary for the driver to work
