-1
Actually, the only way I could access my AWS server is with the IPv4 DNS hostname:
ssh -i '~/.ssh/id_rsa.pub' something.compute.amazonaws.com
I would like to access it with the IPv4 Public IP, but I did not succeed in doing that so far. I tried using the simple command ssh my_ip, but nothing happened.
What do I have to modify on the configuration so that I can use the IP address to access the server.
pa4080
  • 30,621
J.Doe
  • 181
That's because when you're using ssh to the IP, you're not using the key. Try
ssh -i "~/.ssh/id_rsa.pub" server_ip
Also, make sure you're using the external IP of the server
curl ipinfo.io/ip
(check out this question)
user8292439
  • 3,878
  • 32
  • 57
