I've already solved my initial wifi problem here: Wifi drops after ~ 5 minutes with RTL8821AE | Ask Ubuntu but I've tried to optimize it (because anytime there was a kernel update I have to execute all the commands of the solution again) and I've messed up something.
To solve the kernel update problem I tried
sudo dkms add ./rtlwifi_new-master
just before an update. I ran the command in the Desktop folder but I got this output:
Error! Could not find module source directory.
Directory: /usr/src/.-rtlwifi_new-master does not exist.
So I thought that I should have run the given command while in /usr/src/ folder, so I did so, but after doing that my wifi problem got worse and now every time I reboot the PC I need to execute the whole solution again, whereas before this process was necessary only after a kernel update.
Also, on the main screen I see something like
there is an error! rtlwifi_new-master is an external package. Please remove it
In summary:
  1. I got a notification of a system update
  2. I executed sudo dkms add ./rtlwifi_new-master in src folder
  3. I didn't reboot
  4. I executed the update
  5. I rebooted
  6. Worse problem than before
I thought of running
rm -R  rtlwifi-new-0.10
in the /src folder but I don't have the permission and I've already messed up with that one time. You can see it here:
Ubuntu 16.04 lts lost administrator rights bash: /etc/profile: Permission denied | Ask Ubuntu
Suggestions??
Zanna
  • 72,312
First, in terminal, do a man dkms to read/learn about dkms.
Second, assure that any dkms kernel module doesn't already exist in the system, or is older that the source that you're working with.
To install a dkms module, you copy the source code to /usr/src with a folder name in the format of module-version (ie:rtlwifi-0.10). (Adjust the following examples as necessary).
sudo cp -r rtlwifi-new-0.10 /usr/src/rtlwifi-0.10
Then you issue a series of dkms commands like so:
dkms status # to show the current dkms status
Due to your previous attempts, you may have to clean up dkms first, with:
dkms remove module/version -k "$(uname -r)/$(uname -p)"
Then you can start fresh:
sudo dkms add rtlwifi/0.10 -k "$(uname -r)/$(uname -p)"
sudo dkms build rtlwifi/0.10 -k "$(uname -r)/$(uname -p)"
sudo dkms install rtlwifi/0.10 -k "$(uname -r)/$(uname -p)"
dkms status # to show the final dkms status
heynnema
  • 73,649
