When I try to reinstall or remove Software Center, it says
E: Malformed line 7 in source list /etc/apt/sources.list (type)
E: The List of sources could not be read.
Please help.
The error message is telling you the problem. There is a problem on the 7th line of the sources list.
The privileges on that file require that you be root to edit it. in a terminal window, you can
cd /etc/apt
sudo nano sources.list
The system will ask for your password (unless you've done some magic with sudo) and then dump you into the top of the file in the nano editor. Press the down arrow 6 times.
All comment lines should start with a hash (#).
If the line is not a comment line, it should start with deb or deb-src. Compare it to other lines that are not commented, and you may see the error. At worst, as a temporary fix, you can add a hash (#) at the beginning of the line to ignore it as a comment.
Ctrl+O (the letter, not the number) to save, Ctrl+X to exit.
