I recently installed ktechlab and it crashes a lot. So i want to remove it and reinstall it.
i used this link How to install ktechlab?
Follow the exact same instruction from that question, when you came to sudo make install use sudo make uninstall instead, if you were lucky it will be removed nice and easily otherwise you have to find and remove the files one by one manually.
