I am planning to install IBM websphere community edition in Ubuntu.
Could you please suggest how can I extract the wasce_ibm60sdk_setup-3.0.0.4-ppc64linux.tar.bz2 file?
GNU tar (comes with Ubuntu) has the needed algorithm built within to detect the compression algorithm used on the archive file.
So you can just do:
tar -xf abc.tar.bz2
For verbosity, add -v:
tar -xvf abc.tar.bz2
If you want, you can let tar know that it is obviously a bzip2 compressed archive using -j (--bzip2):
tar -xvjf abc.tar.bz2
If you are into BSD style syntax (without leading -) rather than the UNIX one:
tar xvjf abc.tar.bz2
As an alternative you can use:
bunzip2 abc.tar.bz2
to decompress the archive first, then use tar to extract it
tar -xfv abc.tar
