When I use in Matlab
!epstopdf "output.eps" --outfile=output.pdf
then I get one of the following message:
gs: /opt/MATLAB/R2016b/bin/glnxa64/libtiff.so.5: no version information available  (required by /usr/lib/libgs.so.9)
gs: /opt/sw/x86_64/generic/Matlab/R2016b/bin/glnxa64/libtiff.so.5: no version information available (required by /usr/lib64/libgs.so.9)
gs: /opt/sw/x86_64/generic/Matlab/R2017b/bin/glnxa64/libtiff.so.5: no version information available (required by /usr/lib64/libgs.so.9)
I am using Ghostscript 9.18 (default version of Ubuntu 16.04). (Same Problem with Ghostscript 9.07)
JoKalliauer
  • 1,674
  • 20
  • 27
no version information available means that you have an old version (of Ghostscript) see: https://stackoverflow.com/a/156387/6747994
Therefore you have to update to Ghostscript 9.23 (or newer): https://askubuntu.com/a/942995/676490
You have to
JoKalliauer
  • 1,674
  • 20
  • 27
On my system (Linux Mint 21 Vanessa 64-bit), the problem lies in the incompatibility of the libraries libtiff.so.5 and libstdc++.so.6 installed with the system and those shipped with Matlab.
System:
  • /usr/lib/x86_64-linux-gnu/libstdc++.so.6 is a symlink to /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30
  • /usr/lib/x86_64-linux-gnu/libtiff.so.5 is a symlink to /usr/lib/x86_64-linux-gnu/libtiff.so.5.7.0
shipped with the Matlab distribution:
  • R2022b/sys/os/glnxa64/libstdc++.so.6 is a symlink to R2022b/sys/os/glnxa64/libstdc++.so.6.0.28
  • R2022b/bin/glnxa64/libtiff.so.5 is a symlink to R2022b/bin/glnxa64/libtiff.so.5.8.0
To overcome this problem, you need to ensure that the relevant symlinks in the Matlab's library folders point to the system library files rather than those shipped with Matlab. That is:
  • R2022b/sys/os/glnxa64/libstdc++.so.6 must be a symlink to /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30
  • R2022b/bin/glnxa64/libtiff.so.5 must be a symlink to /usr/lib/x86_64-linux-gnu/libtiff.so.5.7.0
This has been an issue for many years, and the above approach always worked. For a particular version of Matlab and your system, you simply need to use the Matlab folder and system libraries that are appropriate for your system (in the above example: R2022b and whatever versions are in the /usr/lib/x86_64-linux-gnu/ folder).
When I use the mex command to compile opencv c++ files or when I use mex files, i get an similar error message like this:
MATLAB/bin/glnxa64/libtiff.so.5: version `LIBTIFF_4.0' not found (required by *)
or
"Invalid MEX-file '.mexa64': libtiff.so.5: version 'LIBTIFF_4.0' not found"(required by /usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4)
I solved it in the following way, please refer to.
sudo rm -rf /usr/local/MATLAB/R2017a/bin/glnxa64/libtiff.so.5
sudo ln -s /usr/lib/x86_64-linux-gnu/libtiff.so.5.2.4 /usr/local/MATLAB/R2017a/bin/glnxa64/libtiff.so.5
The first line of the command removes the libtiff.xo.5 file from its original path. The second command is to link /usr/lib/x86_64-linux-gnu/libtiff.so.5.2.4 to /usr/local/MATLAB/R2017a/bin/glnxa64/libtiff.so.5. This way the two file versions correspond and the problem is solved.
Execute the command locate libtiff.so.5.2.4 You will find this file in the /usr/local/MATLAB/R2017a/bin/glnxa64/ directory. /usr/lib/x86_64-linux-gnu/libtiff.so.5.2.4
Note that the matlab version path above should be the one belonging to you.
xing cui
  • 101
