12
Is there any way to convert a web page and its sub pages into one PDF file?
pa4080
  • 30,621
Tarek
  • 153
Save a list of Web pages as PDF file
  • First install wkhtmltopdf conversion tool (this tool requires desktop environment; source):
    sudo apt install wkhtmltopdf
  • Then create a file that contains a list of URLs of multiple target web pages (each on new line). Let's call this file url-list.txt and let's place it in ~/Downloads/PDF/. For example its content could be:
    https://askubuntu.com/users/721082/tarek
    https://askubuntu.com/users/566421/pa4080
  • And then run the next command, that will generate a PDF file for each site URL, located into the directory where the command is executed:
    while read i; do wkhtmltopdf "$i" "$(echo "$i" | sed -e 's/https\?:\/\///' -e 's/\//-/g' ).pdf"; done < ~/Downloads/PDF/url-list.txt
    The result of this command - executed within the directory ~/Downloads/PDF/ - is:
    ~/Downloads/PDF/$ ls -1 *.pdf
    askubuntu.com-users-566421-pa4080.pdf
    askubuntu.com-users-721082-tarek.pdf
  • Merge the output files by the next command, executed in the above directory (source):
    gs -dBATCH -dNOPAUSE -q -sDEVICE=pdfwrite -dPDFSETTINGS=/prepress -sOutputFile=merged-output.pdf $(ls -1 *.pdf)
    The result is:
    merged-output.pdf
Save an entire Website as PDF file
  • First we must create a file (url-list.txt) that contains URL map of the site. Run these commands (source):
    TARGET_SITE="https://www.yahoo.com/"
    wget --spider --force-html -r -l2 "$TARGET_SITE" 2>&1 | grep '^--' | awk '{ print $3 }' | grep -v '\.\(css\|js\|png\|gif\|jpg\)$' > url-list.txt
  • Then we need go through the steps from the above section.
Create a script that will Save an entire Website as PDF file (recursively)
  • To automate the process we can bring all together in a script file.
  • Create an executable file, called site-to-pdf.sh:
    mkdir -p ~/Downloads/PDF/
    touch ~/Downloads/PDF/site-to-pdf.sh
    chmod +x ~/Downloads/PDF/site-to-pdf.sh
    nano ~/Downloads/PDF/site-to-pdf.sh
  • The script content is:
    #!/bin/sh
    TARGET_SITE="$1"
    wget --spider --force-html -r -l2 "$TARGET_SITE" 2>&1 | grep '^--' | awk '{ print $3 }' | grep -v '\.\(css\|js\|png\|gif\|jpg\|txt\)$' > url-list.txt
    while read i; do wkhtmltopdf "$i" "$(echo "$i" | sed -e 's/https\?:\/\///' -e 's/\//-/g' ).pdf"; done < url-list.txt
    Copy the above content and in nano use: Shift+Insert for paste; Ctrl+O and Enter for save; Ctrl+X for exit.
  • Usage:
The answer to the original question:
Convert multiple PHP files to one PDF (recursively)
  • First install the package enscript, which is a 'regular file to pdf' conversion tool:
    sudo apt update && sudo apt install enscript
  • Then run the next command, that will generate file called output.pdf, located into directory where the command is executed, which will contains the content of all php files within /path/to/folder/ and its sub-directories:
    find /path/to/folder/ -type f -name '*.php' -exec printf "\n\n{}\n\n" \; -exec cat "{}" \; | enscript -o - | ps2pdf - output.pdf
  • Example, from my system, that generated this file:
    find /var/www/wordpress/ -type f -name '*.php' -exec printf "\n\n{}\n\n" \; -exec cat "{}" \; | enscript -o - | ps2pdf - output.pdf
pa4080
  • 30,621
