I have a file called test.sh. I've used chown to set it's owner to user1.
chown user1 test.sh
Then I play with chmod options to see if I understand them correctly.
chmod 400 test.sh
I can read the file but cannot modify or execute it.
chmod 200 test.sh
I can modify the file through command line but cannot read or execute it.
chmod 100 test.sh
I should be able to execute but not modify or read the file. But I get a permission denied error everytime I try to execute without sudo.
What am I doing wrong here?
muru
  • 207,228
You can also try this.
This will add execute permission to owner
chmod u+x file
This will remove execute permission from owner if he had it.
chmod u-x file
first character means who will be affected by this change.
  • u = user - owner
  • g = group - owning group
  • o = other - anyone
  • a = all - same as ugo
second character means if you will add or remove permissions
  • + = add permission
  • - = remove permission
  • = = set permission and overwrite
third character means which permission to apply
for files:
  • r = read - display content of file, copy
  • w = write - change content of file, remove, rename
  • x = execute - run script, program ...
for folders:
  • r = read - display content of folder
  • w = write - create, remove files from directory
  • x = execute - cd into directory
If you want to add write permission for owner to all files in folder, run
chmod u+w -R folder
You can also combine them, so following are valid
chmod ugo+r file
chmod ug+rx file
muru
  • 207,228
FK-VH
  • 188
Basic permissions:
  • Read: r–– → 4
  • Write: –w– → 2
  • Execute: ––x → 1
Most used combinations:
  • Read: r–– → 4+0+0 = 4
  • Read and exec: r–x → 4+0+1 = 5
  • Read and write: rw– → 4+2+0 = 6
  • Read, write and exec: rwx → 4+2+1 = 7
Further reading:
pa4080
  • 30,621
