Trying to install TeamViewer on Ubuntu 14.04 AWS EC2 instance with K80 GPU. Currently I have ubuntu-desktop running and TightVNC working.
The TeamViewer tar version works fine (I can connect remotely using my ID and password), but the installed version keeps displaying Not ready. Please check your connection.
I tried:
- Rebooting
- Stopping and starting the daemon
- Installing with apt-get, gdebi, manually (basically everything from Installed Teamviewer using a 64-bit system, but I get a dependency error)
- A bunch of other stuff...
I thought the problem has something to do with the framebuffer errors so I followed https://community.teamviewer.com/t5/Linux/Teamviewer-Host-EC2-Ubuntu-Server-The-framebuffer-console-seems/m-p/9964 but it didn't help.
Here's the TeamViewer log if that helps...
2017/07/31 20:23:15.075 4029 140044686686080 gX1 Logger started.
2017/07/31 20:23:15.076 4029 140044686686080 gX1 Found 0 Minidump files ...
2017/07/31 20:23:15.076 4029 140044686686080 gX1 Found 0 core dump files ...
2017/07/31 20:23:15.077 4029 140044686686080 gX1 systemd: logind service available
2017/07/31 20:23:15.078 4029 140044686686080 gX1 systemd: New seat seat0 [path=/org/freedesktop/login1/seat/seat0, activeSession='', canGraphical=1, canTTY=1, canMultiSession=1]
2017/07/31 20:23:15.082 4029 140044686686080 gX1 SystemdSessionInfo: New session SystemdSessionInfo [id=1 user=ubuntu state=user active=1 reliable=1 infoId=0] [path=/org/freedesktop/login1/session/_31 TTY= seat= display= vtnr=4294967295 owner=[SysUser_Lin: ubuntu [uid=1000, gid=1000 home=/home/ubuntu gecos=Ubuntu shell=/bin/bash]] idle=0(1501532593207174) active=1 type=tty class=user state=active timestamp=1501529883809932 service=sshd defaultCG=systemd:/user/1000.user/1.session leader=1849 audit=1 remote=1 rHost=bzq-109-66-122-182.red.bezeqint.net rUser= killProc=0]
2017/07/31 20:23:15.082 4029 140044686686080 gX1 SysSessionInfoManager: Session Information provided by systemd [priority: 0]
2017/07/31 20:23:15.082 4029 140044686686080 gX1 SysSessionInfoManager: Session Information provided by VT [priority: 2]
2017/07/31 20:23:15.082 4029 140044686686080 gX1 XSocket observer: watching /tmp/.X11-unix
2017/07/31 20:23:15.082 4029 140044686686080 gX1 XSocket observer: adding XSession: 1
2017/07/31 20:23:15.096 4029 140044686686080 gX1 FBSessionObserver: Framebuffer device /dev/fb0 has 24bit depth. Only 32bit and 16bit are supported.
2017/07/31 20:23:15.096 4029 140044686686080 gX1! FrameBuffer: Cannot access /dev/fb0, frame buffer support unavailable
2017/07/31 20:23:15.097 4029 140044686686080 gX1! XSession: Reading TTY from X-Server process failed.
2017/07/31 20:23:15.097 4029 140044686686080 gX1 XSession[1]: Retrieved XAuth from commandline
2017/07/31 20:23:15.098 4029 140044686686080 gX1! VTSessionInfoProvider: Failed setting TTY for session 1 on display ':1'
2017/07/31 20:23:15.098 4029 140044686686080 gX1 SysSessionInfoManager: assigned session 1 to info provider 'None'
2017/07/31 20:23:15.100 4029 140044686686080 gX1!!!XFixes extension not found, Errorcode=11
2017/07/31 20:23:15.100 4029 140044686686080 gX1 TVGuiSlave.64: Running
2017/07/31 20:23:15.084 4030 4113991424 QX1 Logger started.
2017/07/31 20:23:15.085 4030 4113991424 QX1 Found 0 Minidump files ...
2017/07/31 20:23:15.085 4030 4113991424 QX1 Found 0 core dump files ...
2017/07/31 20:23:15.087 4030 4113991424 QX1 systemd: logind service available
2017/07/31 20:23:15.088 4030 4113991424 QX1 systemd: New seat seat0 [path=/org/freedesktop/login1/seat/seat0, activeSession='', canGraphical=1, canTTY=1, canMultiSession=1]
2017/07/31 20:23:15.091 4030 4113991424 QX1 SystemdSessionInfo: New session SystemdSessionInfo [id=1 user=ubuntu state=user active=1 reliable=1 infoId=0] [path=/org/freedesktop/login1/session/_31 TTY= seat= display= vtnr=4294967295 owner=[SysUser_Lin: ubuntu [uid=1000, gid=1000 home=/home/ubuntu gecos=Ubuntu shell=/bin/bash]] idle=0(1501532593207174) active=1 type=tty class=user state=active timestamp=1501529883809932 service=sshd defaultCG=systemd:/user/1000.user/1.session leader=1849 audit=1 remote=1 rHost=bzq-109-66-122-182.red.bezeqint.net rUser= killProc=0]
2017/07/31 20:23:15.091 4030 4113991424 QX1 SysSessionInfoManager: Session Information provided by systemd [priority: 0]
2017/07/31 20:23:15.092 4030 4113991424 QX1 SysSessionInfoManager: Session Information provided by VT [priority: 2]
2017/07/31 20:23:15.092 4030 4113991424 QX1 XSocket observer: watching /tmp/.X11-unix
2017/07/31 20:23:15.092 4030 4113991424 QX1 XSocket observer: adding XSession: 1
2017/07/31 20:23:15.106 4030 4113991424 QX1 FBSessionObserver: Framebuffer device /dev/fb0 has 24bit depth. Only 32bit and 16bit are supported.
2017/07/31 20:23:15.106 4030 4113991424 QX1! FrameBuffer: Cannot access /dev/fb0, frame buffer support unavailable
2017/07/31 20:23:15.107 4030 4113991424 QX1! XSession: Reading TTY from X-Server process failed.
2017/07/31 20:23:15.108 4030 4113991424 QX1 XSession[1]: Retrieved XAuth from commandline
2017/07/31 20:23:15.108 4030 4113991424 QX1! VTSessionInfoProvider: Failed setting TTY for session 1 on display ':1'
2017/07/31 20:23:15.108 4030 4113991424 QX1 SysSessionInfoManager: assigned session 1 to info provider 'None'
2017/07/31 20:23:15.110 4030 4113991424 QX1 TVGuiDelegate: Running
2017/07/31 20:23:15.266 4029 140044497045248 gX1 Audio: PulseAudio enabled
2017/07/31 20:23:15.268 4029 140044482193152 gX1!! PulseAudio: Context failed: Connection refused, Errorcode=2
2017/07/31 20:23:15.268 4029 140044482193152 gX1!! PulseAudio: Unable to connect to server, no server running?, Errorcode=2
2017/07/31 20:23:15.268 4029 140044497045248 gX1!! Audio: Unable to initialise PulseAudio
2017/07/31 20:23:14.632 8 26 GX1 Logger started.
2017/07/31 20:23:14.656 8 26 GX1 StringCompare locale: English_United States.1252
2017/07/31 20:23:15.050 8 26 GX1!! SetProcessStartupOptions(): SetProcessDEPPolicy() failed! LE=120, Errorcode=87
2017/07/31 20:23:15.068 8 26 GX1 TVW X ErrorHandler org 7e88fb17, def 7e71f8f0 cur 7dd153eb
2017/07/31 20:23:15.072 8 26 GX1 Wine: Wine DLL initialized
2017/07/31 20:23:15.072 8 26 GX1 Wine: wine-1.6
2017/07/31 20:23:15.072 8 26 GX1 TVW SID0: SpawnSlave: pid 0
2017/07/31 20:23:15.072 8 26 GX1 TVW SID0: SpawnSlave: loading TVGuiSlave.64
2017/07/31 20:23:15.076 8 26 GX1 TVW ObserveFork: OK
2017/07/31 20:23:15.076 8 26 GX1 Wine: Spawned slave process with type 0
2017/07/31 20:23:15.077 8 26 GX1 TVW SID1: SpawnSlave: pid 0
2017/07/31 20:23:15.077 8 26 GX1 TVW SID1: SpawnSlave: loading TVGuiDelegate
2017/07/31 20:23:15.085 8 26 GX1 TVW ObserveFork: OK
2017/07/31 20:23:15.086 8 26 GX1 Wine: Spawned slave process with type 1
2017/07/31 20:23:15.087 8 26 GX1 Starting GUI master for slave type 0
2017/07/31 20:23:15.100 8 26 GX1 Slave connected to GUI master
2017/07/31 20:23:15.101 8 26 GX1 Starting GUI master for slave type 1
2017/07/31 20:23:15.111 8 26 GX1 Slave connected to GUI master
2017/07/31 20:23:15.139 8 26 GX1 Monitors: X11 Windowing System, \\.\DISPLAY1, 1024x768 (0,0), flags=21, dpi=96
2017/07/31 20:23:15.164 8 26 GX1 CMain::LoadResourceDLLs(): No custom resource dll found
2017/07/31 20:23:15.164 8 26 GX1 InterProcessBase::SecureNetwork created
2017/07/31 20:23:15.171 8 26 GX1 AutoLogin::Login: enabled: 1
Start: 2017/07/31 20:23:15.171 (UTC)
Version: 12.0.76279
Loglevel: LogAll (0)
License: 0
Server: master5.teamviewer.com
IC: 0
CPU: x86 Family 6 Model 79 Stepping 1, GenuineIntel
CPU extensions: h9
OS: Lx Ubuntu 14.04.5 LT (32-bit)
IP: 172.31.48.116
Proxy-Settings: Type=0 IP= User=
AppPath: C:\TeamViewer\TeamViewer.exe
UserAccount: ubuntu
2017/07/31 20:23:15.176 8 26 GX1 Win32_GUI::FontReallyExists: 'Segoe UI' found 0 matches.
2017/07/31 20:23:15.176 8 26 GX1 Win32_GUI::FontReallyExists: 'Liberation Sans' found 4 matches.
2017/07/31 20:23:15.182 8 26 GX1 InterProcessBase::StartTcpCommunicationInternal(): setting m_NetworkConnector to new TCP connector
2017/07/31 20:23:15.182 8 26 GX1 Opening local TCP connection to 127.0.0.1:5939
2017/07/31 20:23:15.182 8 26 GX1 Local TCP connection established
2017/07/31 20:23:15.183 8 26 GX1 Process ID: L 3889 / W 8
2017/07/31 20:23:15.264 8 26 GX1 SettingsIPCReception receive a SYNCHRONISE Settings command : UserSettings
2017/07/31 20:23:15.264 8 26 GX1 Received Control_InitIPC_Response processtype=1
2017/07/31 20:23:15.265 8 26 GX1 Received Control_InitIPC_Response runningProcesses=3
2017/07/31 20:23:15.265 8 26 GX1 Control_InitIPC_Response: all processes 3 completely initialized
2017/07/31 20:23:15.271 8 26 GX1 Slave signalized initialization
2017/07/31 20:23:15.300 8 31 GX1 ProxySearch: no PAC script detected via WPAD
2017/07/31 20:23:15.303 8 31 GX1 ProxySearch: no PAC script detected via WPAD
rent session available (yet)
2017/07/31 20:23:15.358 8 28 GX1 Slave signalized initialization
2017/07/31 20:23:15.359 8 9 GX1 tvshared::WindowsSessionStateManager::WindowsSessionStateManager(0232F338) state 0
2017/07/31 20:23:15.359 8 9 GX1 VoIP: VoIPCentral: Set capturing-device = "", rendering-device = ""
2017/07/31 20:23:15.360 4029 140044473800448 gX1!! PulseAudio: Context failed: Connection refused, Errorcode=2
2017/07/31 20:23:15.360 4029 140044473800448 gX1!! PulseAudio: Unable to connect to server, no server running?, Errorcode=2
2017/07/31 20:23:15.360 4029 140044497045248 gX1 ALSA: No cards of type 0 found
2017/07/31 20:23:15.360 4029 140044497045248 gX1 ALSA: No cards of type 1 found
2017/07/31 20:23:15.361 8 9 GX1 MachineID m=1 - 1
2017/07/31 20:23:15.362 8 9 GX1 TVUpdate::Init() Version-URL: download.teamviewer.com/download/update/ Update-URL: download.teamviewer.com/download/update/
2017/07/31 20:23:15.364 8 9 GX1 TVUpdate::Init() Preview Channel Number : 1
2017/07/31 20:23:15.366 8 9 GX1 DynamicPasswordUIModel::ShouldShowDynamicPassword(): dynPw=1 allowIncoming=1 id=0 ka=0 lanAllowed=0 lanOnly=0 networkState=1 showDynPwd=0
2017/07/31 20:23:15.369 8 9 GX1!! MachineHooks: Library not found, Errorcode=126
2017/07/31 20:23:15.447 8 9 GX1 Wine: HwndToWindow 00010058 -> 2600002
2017/07/31 20:23:15.447 8 9 GX1 ManagerHolderStateMachine: Switching from None to NotReady
2017/07/31 20:23:15.447 8 23 GX1 ChatManager::ChatManager: created
2017/07/31 20:23:15.447 8 23 GX1 ChatManager::Factory: ChatManager created
2017/07/31 20:23:15.448 8 23 GX1 IncomingBetterChatCommandHandler::IncomingBetterChatCommandHandler: created
2017/07/31 20:23:15.448 8 9 GX1!! DragDropRegistration: could not register window, HR=80040155
2017/07/31 20:23:15.448 8 23 GX1 IncomingChatCommandRegistration::Start: registering for ready state properties
2017/07/31 20:23:15.450 8 9 GX1 AccountLoginGUI::CreateLoginKey(): [OnlineState] System is set to Visible.
2017/07/31 20:23:15.473 8 9 GX1 Wine: HwndToWindow 00010058 -> 2600002
2017/07/31 20:23:15.473 8 9 GX1 Wine: HwndToWindow 000100C6 -> 2600005
2017/07/31 20:23:15.476 8 9 GX1 CMainWindow::ShouldShowDynamicPassword(): dynPw=1 allowIncoming=1 id=0 ka=0 lanAllowed=0 lanOnly=0 networkState=1 showDynPwd=0
2017/07/31 20:23:15.478 8 9 GX1!! ServerControl: RegisterPowerSettingNotification failed with error 0
2017/07/31 20:23:15.510 4029 140044473800448 gX1!! PulseAudio: Context failed: Connection refused, Errorcode=2
2017/07/31 20:23:15.510 4029 140044473800448 gX1!! PulseAudio: Unable to connect to server, no server running?, Errorcode=2
2017/07/31 20:23:15.511 4029 140044497045248 gX1 ALSA: No cards of type 0 found
2017/07/31 20:23:15.511 4029 140044497045248 gX1 ALSA: No cards of type 1 found
2017/07/31 20:23:15.513 4029 140044497045248 gX1!! ALSAMixer: Unable to attach mixer to device default (No such file or directory) [Master] on default, Errorcode=2
2017/07/31 20:23:15.513 4029 140044497045248 gX1!! ALSAMixer: Unable to attach mixer to device default (No such file or directory) [Capture] on default, Errorcode=2
2017/07/31 20:23:15.513 8 33 GX1!! WineMixer: Unable to initialise mixer -1 -1
2017/07/31 20:23:15.514 8 33 GX1 VoIP: VoIPCentral: Set capturing-device = "", rendering-device = ""
2017/07/31 20:23:15.556 8 9 GX1!! TVW Wine: SetWindowManagerClassHint: No such window
2017/07/31 20:23:25.319 4030 4030724928 QX1! SessionBusWatcher: no suitable session bus found
