I have some trouble booting my Ubuntu laptop, sometimes it works, most of the times it doesn't. Result of smartctl -a seems to be that my HDD is health so I am investigating other posibilities. Details about my system and errors are in this question.
I found in my syslog the recurring error bellow. Some people had the same dificulties booting the OS and found PSU was to blame or some cable. Their errors were not identical to mine though.
What do you think can cause this error?
Jul 30 20:22:25 gabi-Inspiron-5521 nm-dispatcher: req:1 'hostname': start running ordered scripts...
Jul 30 20:22:25 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438945.4073] Loaded device plugin: NMVethFactory (internal)
Jul 30 20:22:25 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438945.4073] Loaded device plugin: NMTunFactory (internal)
Jul 30 20:22:25 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438945.4073] Loaded device plugin: NMMacvlanFactory (internal)
Jul 30 20:22:25 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438945.4073] Loaded device plugin: NMIPTunnelFactory (internal)
Jul 30 20:22:25 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438945.4074] Loaded device plugin: NMInfinibandFactory (internal)
Jul 30 20:22:25 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438945.4074] Loaded device plugin: NMEthernetFactory (internal)
Jul 30 20:22:25 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438945.4074] Loaded device plugin: NMBridgeFactory (internal)
Jul 30 20:22:25 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438945.4075] Loaded device plugin: NMBondFactory (internal)
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039736] ata1.00: exception Emask 0x10 SAct 0x7c204 SErr 0x280100 action 0x6 frozen
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039740] ata1.00: irq_stat 0x08000000, interface fatal error
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039742] ata1: SError: { UnrecovData 10B8B BadCRC }
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039744] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039747] ata1.00: cmd 60/20:10:f0:f3:04/00:00:5b:00:00/40 tag 2 ncq dma 16384 in
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039747] res 40/00:74:00:90:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039748] ata1.00: status: { DRDY }
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039750] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039752] ata1.00: cmd 60/c8:48:d8:f7:0e/00:00:00:00:00/40 tag 9 ncq dma 102400 in
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039752] res 40/00:74:00:90:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039753] ata1.00: status: { DRDY }
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039754] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039757] ata1.00: cmd 60/00:70:00:90:29/01:00:00:00:00/40 tag 14 ncq dma 131072 in
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039757] res 40/00:74:00:90:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039758] ata1.00: status: { DRDY }
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039759] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039762] ata1.00: cmd 60/08:78:60:3a:84/00:00:24:00:00/40 tag 15 ncq dma 4096 in
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039762] res 40/00:74:00:90:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039763] ata1.00: status: { DRDY }
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039764] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039766] ata1.00: cmd 60/20:80:20:ee:04/00:00:5b:00:00/40 tag 16 ncq dma 16384 in
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039766] res 40/00:74:00:90:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039768] ata1.00: status: { DRDY }
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039769] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039771] ata1.00: cmd 60/08:88:e0:19:41/00:00:5e:00:00/40 tag 17 ncq dma 4096 in
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039771] res 40/00:74:00:90:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039772] ata1.00: status: { DRDY }
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039773] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039776] ata1.00: cmd 60/00:90:00:91:29/01:00:00:00:00/40 tag 18 ncq dma 131072 in
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039776] res 40/00:74:00:90:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039777] ata1.00: status: { DRDY }
Jul 30 20:22:25 gabi-Inspiron-5521 kernel: [ 28.039780] ata1: hard resetting link
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 28.355550] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 28.368567] ata1.00: configured for UDMA/133
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 28.368596] ata1: EH complete
Jul 30 20:22:26 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438946.4377] Loaded device plugin: NMBluezManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-bluetooth.so)
Jul 30 20:22:26 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438946.5443] Loaded device plugin: NMWifiFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-wifi.so)
Jul 30 20:22:26 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438946.5994] Loaded device plugin: NMAtmManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-adsl.so)
Jul 30 20:22:26 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438946.7897] Loaded device plugin: NMWwanFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-wwan.so)
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171832] ata1.00: exception Emask 0x10 SAct 0x45804000 SErr 0x280100 action 0x6 frozen
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171836] ata1.00: irq_stat 0x08000000, interface fatal error
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171837] ata1: SError: { UnrecovData 10B8B BadCRC }
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171839] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171842] ata1.00: cmd 60/20:70:20:eb:04/00:00:5b:00:00/40 tag 14 ncq dma 16384 in
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171842] res 40/00:f4:00:a9:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171844] ata1.00: status: { DRDY }
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171845] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171848] ata1.00: cmd 60/00:b8:48:0b:06/01:00:5b:00:00/40 tag 23 ncq dma 131072 in
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171848] res 40/00:f4:00:a9:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171849] ata1.00: status: { DRDY }
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171850] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171853] ata1.00: cmd 60/98:c0:f0:c4:0e/00:00:00:00:00/40 tag 24 ncq dma 77824 in
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171853] res 40/00:f4:00:a9:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171854] ata1.00: status: { DRDY }
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171855] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171858] ata1.00: cmd 60/08:d0:70:3a:84/00:00:24:00:00/40 tag 26 ncq dma 4096 in
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171858] res 40/00:f4:00:a9:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171859] ata1.00: status: { DRDY }
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171860] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171862] ata1.00: cmd 60/00:f0:00:a9:29/01:00:00:00:00/40 tag 30 ncq dma 131072 in
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171862] res 40/00:f4:00:a9:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171864] ata1.00: status: { DRDY }
Jul 30 20:22:26 gabi-Inspiron-5521 kernel: [ 29.171866] ata1: hard resetting link
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.487317] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.500370] ata1.00: configured for UDMA/133
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.500386] ata1: EH complete
Jul 30 20:22:27 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438947.4607] manager: (enp7s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/0)
Jul 30 20:22:27 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438947.4616] keyfile: add connection in-memory (b5ce8d04-fd92-3051-9b9a-03e4d3a23223,"Wired connection 1")
Jul 30 20:22:27 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438947.4619] settings: (enp7s0): created default wired connection 'Wired connection 1'
Jul 30 20:22:27 gabi-Inspiron-5521 NetworkManager[908]: <info> [1501438947.4627] device (enp7s0): state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.689369] IPv6: ADDRCONF(NETDEV_UP): enp7s0: link is not ready
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915859] ata1.00: exception Emask 0x10 SAct 0x1260010 SErr 0x280100 action 0x6 frozen
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915863] ata1.00: irq_stat 0x08000000, interface fatal error
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915865] ata1: SError: { UnrecovData 10B8B BadCRC }
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915867] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915870] ata1.00: cmd 60/d0:20:08:c0:0e/00:00:00:00:00/40 tag 4 ncq dma 106496 in
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915870] res 40/00:8c:00:d4:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915872] ata1.00: status: { DRDY }
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915873] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915876] ata1.00: cmd 60/00:88:00:d4:29/01:00:00:00:00/40 tag 17 ncq dma 131072 in
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915876] res 40/00:8c:00:d4:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915877] ata1.00: status: { DRDY }
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915878] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915881] ata1.00: cmd 60/08:90:78:0b:81/00:00:32:00:00/40 tag 18 ncq dma 4096 in
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915881] res 40/00:8c:00:d4:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915882] ata1.00: status: { DRDY }
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915884] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915886] ata1.00: cmd 60/20:a8:30:e6:04/00:00:5b:00:00/40 tag 21 ncq dma 16384 in
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915886] res 40/00:8c:00:d4:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915887] ata1.00: status: { DRDY }
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915889] ata1.00: failed command: READ FPDMA QUEUED
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915891] ata1.00: cmd 60/20:c0:e0:3a:84/00:00:24:00:00/40 tag 24 ncq dma 16384 in
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915891] res 40/00:8c:00:d4:29/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915892] ata1.00: status: { DRDY }
Jul 30 20:22:27 gabi-Inspiron-5521 kernel: [ 29.915895] ata1: hard resetting link
Jul 30 20:22:28 gabi-Inspiron-5521 kernel: [ 30.231520] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
EDIT: HDD as described by smartctl
Model Family: Seagate Samsung SpinPoint M8 (AF)
Device Model: ST1000LM024 HN-M101MBB
Serial Number: S2WZJ90CB67655
LU WWN Device Id: 5 0004cf 208e1e1da
Firmware Version: 2AR20003
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5400 rpm
Form Factor: 2.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 6
SATA Version is: SATA 3.0, 3.0 Gb/s (current: 1.5 Gb/s)
Local Time is: Mon Jul 31 17:40:33 2017 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
