EDIT: I just ran lsmod in the terminal and this was listed
cp210x 24576 0
So maybe it is already installed and I don't have to do anything/something else is keeping the GPS from communicating with the program? Is there anything special that would need to be done to allow it to work with Wine?
I'm new to Linux/Ubuntu, so I'm sorry this is sort of stupid. I have a GPS for geocaching (http://www.b4adventure.com/geomatejr/) and to use it, you need the CP210x driver from Silas Labs. I saw there was a Linux driver and thought that would work, however, I'm confused by the "build notes." It doesn't have the exact code to copy into the terminal (or have a convenient installation package :) ).
Here is what the instructions say:
- make ( your cp210x driver )
- cp cp210x.ko to
/lib/modules/<kernel-version>/kernel/drivers/usb/serial insmod /lib/modules/<kernel-version/kernel/drivers/usb/serial/usbserial.koinsmod cp210x.ko
Now, the download has four files, the release notes (above), cp210x.c, cp210x_gpio_example.c, and Makefile. I'm assuming the first step uses the Makefile, but I don't know enough about code stuff/Ubuntu to know exactly what I'm supposed to type/what to do.
The Makefile has this:
obj-m = cp210x.o
KVERSION = $(shell uname -r)
all:
make -C /lib/modules/$(KVERSION)/build M=$(PWD) modules
clean:
make -C /lib/modules/$(KVERSION)/build M=$(PWD) clean
Is KVERSION supposed to be 4.4.0-87-generic (the newest/highest number in the lib/modules folder)? And then PWD my password, maybe? I don't want to ruin stuff by randomly typing code into the terminal so I'd appreciate some guidance! Step-by-step help would be very, very much appreciated!!!
modinfo usbserial # get info on this kernel module
filename: /lib/modules/4.4.0-87-generic/kernel/drivers/usb/serial/usbserial.ko
license: GPL
description: USB Serial Driver core
author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
srcversion: AB3F1BFEDF75B5D214FAAD2
depends:
intree: Y
vermagic: 4.4.0-87-generic SMP mod_unload modversions
parm: vendor:User specified USB idVendor (ushort)
parm: product:User specified USB idProduct (ushort)
modinfo cp210x # get info on this kernel module
filename: /lib/modules/4.4.0-87-generic/kernel/drivers/usb/serial/cp210x.ko
license: GPL
description: Silicon Labs CP210x RS232 serial adaptor driver
srcversion: 2943505BFE400A2778D74E5
alias: usb:v413Cp9500d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v3195pF281d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v3195pF280d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v3195pF190d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2626pEA60d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0701d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0700d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0602d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0601d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0600d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0404d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0403d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0402d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0401d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0400d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0303d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0302d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0301d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0300d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0203d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0202d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0201d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0200d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1FB9p0100d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1E29p0501d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1E29p0102d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1D6Fp0010d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1BE3p07A6d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1BA4p0002d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1B1Cp1C00d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1ADBp0001d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v19CFp3000d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1901p0196d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1901p0195d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1901p0194d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1901p0193d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1901p0190d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v18EFpE025d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v18EFpE00Fd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1843p0200d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v17F4pAAAAd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v17A8p0005d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v17A8p0001d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v16DCp0015d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v16DCp0012d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v16DCp0011d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v16DCp0010d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v16D6p0001d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v16C0p09B1d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v16C0p09B0d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v166Ap0101d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v166Ap0401d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v166Ap0305d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v166Ap0304d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v166Ap0303d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v166Ap0301d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v166Ap0201d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v1555p0004d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v13ADp9999d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v12B8pEC62d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v12B8pEC60d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10CEpEA6Ad*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C5pEA61d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4pF004d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4pF003d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4pF002d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4pF001d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4pEA71d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4pEA70d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4pEA61d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4pEA60d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8A2Ad*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8998d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8977d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8962d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8946d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p88A5d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p88A4d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8857d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8856d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8665d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8664d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p85F8d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p85EBd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p85EAd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p84B6d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8477d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8470d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p846Ed*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8418d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8411d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p83D8d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p83A8d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8382d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8341d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p82F9d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p82F4d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8293d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8281d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p826Bd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p822Bd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8218d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p81F2d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p81E8d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p81E7d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p81E2d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p81D7d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p81C8d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p81ADd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p81ACd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p81A9d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p81A6d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p819Fd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p818Bd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p815Fd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p815Ed*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8156d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v2405p0003d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p814Bd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p814Ad*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p813Fd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p813Dd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8115d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p80F6d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p80DDd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p80CAd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p80C4d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p807Ad*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p806Fd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8066d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8054d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8053d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p804Ed*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p8044d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p803Bd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p800Ad*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p1601d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p1101d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10C4p0F91d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10B5pAC70d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10ABp10C5d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v10A6pAA26d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0FDEpCA05d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0FCFp1006d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0FCFp1004d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0FCFp1003d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0BEDp1101d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0BEDp1100d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0908p01FFd*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v08FDp000Ad*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v08E6p5501d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0846p1100d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0745p1000d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0489pE003d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0489pE000d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0471p066Ad*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v045Bp0053d*dc*dsc*dp*ic*isc*ip*in*
depends: usbserial
intree: Y
