When I execute gksudo, I get some output in the terminal, I want to supress that output, but still get the output from the actual command. For example:
$ gksudo whoami
> #some gksudo related output
> root
When I try to dump the output to /dev/null like this:
$ gksudo &> /dev/null whoami
I get the prompt message without output, but the whoami result is also supressed.
I realise this is resolved now but just picking on your comment:
I want to launch root commands from a GUI application, if there is a better way to prompt graphically for the sudo password I would like to know
pkexec is a relatively modern alternative that works slightly out of band compared to sudo/gksu. It should be available on all the Ubuntu desktops.
Oli
  • 299,380
All errors in a terminal are sent to stderr. To prevent displaying an error, you might need to redirect stderr, like this:
gksudo whoami 2> /dev/null
Eliah Kagan
  • 119,640
ob2
  • 3,653
