I'm a not talented Ubuntu user and I have a problem with wi-fi and Ubuntu 16.04.
It started with 14.04, when an update failed (it stopped before finishing) and the Wi-Fi disappeared from the networking tab. I tried something without success, then I decided to upgrade to 16.04 (via LAN).
By mistake I kept an old configuration file, but everything worked
well except that Wi-Fi still does not work. I disabled Secure Boot from bios (and tried some other random actions) with basically no effect: while the Enable Wi-Fi option was present in the networking tab, there was the indication Wi-Fi is disabled under Wi-Fi Networks.
The Network driver selected in Software & Updates > Additional drivers is Broadcom 802.11 from bclwm-kernel-source.
I tried to follow what is suggested in Qualcomm Atheros Device [168c:0042] (rev 30) Wi-Fi driver installation
But the only result was that Enable Wi-Fi disappeared from the networking menu.
How can I fix it?
Thanks for the comments.
I am afraid that following Qualcomm Atheros Device [168c:0042] (rev 30) Wi-Fi driver installation messed up everything.
I add the result of
lspci -knn | grep Net -A3; rfkill list
02:00.0 Network controller [0280]: Broadcom Limited BCM4352 802.11ac Wireless Network Adapter [14e4:43b1] (rev 03)
Subsystem: Dell BCM4352 802.11ac Wireless Network Adapter [1028:0019]
Kernel modules: wl, bcma
I'm sorry if I'm wrong but I have the impression my question is different from Why do I get "Required key not available" when install 3rd party kernel modules or after a kernel upgrade?. In my case Secure Boot has been disabled from bios since the very beginning.
Additional information
result of sudo apt install --reinstall bcmwl-kernel-source
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/1.544 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 939933 files and directories currently installed.)
Preparing to unpack .../bcmwl-kernel-source_6.30.223.271+bdcom-0ubuntu1~1.1_amd64.deb ...
Removing all DKMS Modules
Done.
Unpacking bcmwl-kernel-source (6.30.223.271+bdcom-0ubuntu1~1.1) over (6.30.223.271+bdcom-0ubuntu1~1.1) ...
Setting up bcmwl-kernel-source (6.30.223.271+bdcom-0ubuntu1~1.1) ...
Loading new bcmwl-6.30.223.271+bdcom DKMS files...
Building only for 4.4.0-87-generic
Building for architecture x86_64
Building initial module for 4.4.0-87-generic
Done.
wl:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/4.4.0-87-generic/updates/dkms/
depmod....
DKMS: install completed.
modprobe: ERROR: could not insert 'wl': Invalid argument
update-initramfs: deferring update (trigger activated)
Processing triggers for shim-signed (1.32~16.04.1+0.9+1474479173.6c180c6-1ubuntu1) ...
Secure Boot not enabled on this system.
Processing triggers for initramfs-tools (0.122ubuntu8.8) ...
update-initramfs: Generating /boot/initrd.img-4.4.0-87-generic
