I have just installed 16.04 on my HP-149tx alongside Windows. I am unable to access the Wifi from Ubuntu. The signal is too weak even if I hold the laptop close to the router.I can confirm this is a driver issue since I have flawless access to my Wifi from Windows.
What I did to try and rectify this issue is try to download and install the wifi drivers as per instructions specified over here. The problem I get when installing the driver is as follows-:
(Reading database ... 174937 files and directories currently installed.)
Preparing to unpack rtlwifi-new-dkms_0.10_all.deb ...
Deleting module version: 0.10
completely from the DKMS tree.
Done.
Unpacking rtlwifi-new-dkms (0.10) over (0.10) ...
Setting up rtlwifi-new-dkms (0.10) ...
Loading new rtlwifi-new-0.10 DKMS files...
First Installation: checking all kernels...
Building only for 4.8.0-36-generic
Building for architecture x86_64
Building initial module for 4.8.0-36-generic
Error! Bad return status for module build on kernel: 4.8.0-36-generic (x86_64)
Consult /var/lib/dkms/rtlwifi-new/0.10/build/make.log for more information.
Also the contents of make.log is as follows-:
DKMS make.log for rtlwifi-new-0.10 for kernel 4.8.0-36-generic (x86_64)
Sun Jul 30 17:10:27 IST 2017
make: Entering directory '/usr/src/linux-headers-4.8.0-36-generic'
LD /var/lib/dkms/rtlwifi-new/0.10/build/built-in.o
CC [M] /var/lib/dkms/rtlwifi-new/0.10/build/base.o
In file included from /var/lib/dkms/rtlwifi-new/0.10/build/base.c:30:0:
/var/lib/dkms/rtlwifi-new/0.10/build/wifi.h:1327:40: error: ‘IEEE80211_NUM_BANDS’ undeclared here (not in a function)
struct ieee80211_supported_band bands[IEEE80211_NUM_BANDS];
/var/lib/dkms/rtlwifi-new/0.10/build/base.c:138:10: error: ‘IEEE80211_BAND_2GHZ’ undeclared here (not in a function)
.band = IEEE80211_BAND_2GHZ,
/var/lib/dkms/rtlwifi-new/0.10/build/base.c:150:10: error: ‘IEEE80211_BAND_5GHZ’ undeclared here (not in a function)
.band = IEEE80211_BAND_5GHZ,
scripts/Makefile.build:289: recipe for target '/var/lib/dkms/rtlwifi-new/0.10/build/base.o' failed
make[1]: *** [/var/lib/dkms/rtlwifi-new/0.10/build/base.o] Error 1
Makefile:1491: recipe for target '_module_/var/lib/dkms/rtlwifi-new/0.10/build' failed
make: *** [_module_/var/lib/dkms/rtlwifi-new/0.10/build] Error 2
make: Leaving directory '/usr/src/linux-headers-4.8.0-36-generic'
I can confirm that my wifi lan card is a Realtek RTL8723BE device since that is what my Windows OS recognizes it as and I have installed the Windows equivalent driver for it and it working fine there.
The output from modinfo rtl8723be is as follows-:
alex@alex-HP-Notebook:~/Desktop/rtlwifi_new-master$ modinfo rtl8723be
filename: /lib/modules/4.8.0-36-generic/kernel/drivers/net/wireless/realtek/rtlwifi/rtl8723be/rtl8723be.ko
firmware: rtlwifi/rtl8723befw.bin
description: Realtek 8723BE 802.11n PCI wireless
license: GPL
author: Realtek WlanFAE <wlanfae@realtek.com>
author: PageHe <page_he@realsil.com.cn>
srcversion: 1520FD8B69687790125304A
alias: pci:v000010ECd0000B723sv*sd*bc*sc*i*
depends: rtlwifi,rtl8723-common,rtl_pci,btcoexist,mac80211
intree: Y
vermagic: 4.8.0-36-generic SMP mod_unload modversions
parm: swenc:Set to 1 for software crypto (default 0)
(bool)
parm: ips:Set to 0 to not use link power save (default 1)
(bool)
parm: swlps:Set to 1 to use SW control power save (default 0)
(bool)
parm: fwlps:Set to 1 to use FW control power save (default 1)
(bool)
parm: msi:Set to 1 to use MSI interrupts mode (default 0)
(bool)
parm: debug:Set debug level (0-5) (default 0) (int)
parm: disable_watchdog:Set to 1 to disable the watchdog (default 0)
(bool)
parm: ant_sel:Set to 1 or 2 to force antenna number (default 0)
Also my router is configured with the following parameters-:
Wireless Band: 2.4 GHz
802.11 Mode: Mixed 802.11n, 802.11g, 802.11b
Auto Channel Scan enabled
Wireless Channel : 2.437 GHz - CH 6
Channel Width: Auto 20/40 MHz
