Ok so i'm trying to build from source and to do that I must install it's dependencies.
So one of the dependencies is the following:
karl@karl-ux303ln:~/dev/RBDOOM-3-BFG/neo(master)$ sudo apt-get install libsdl2-dev
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
libsdl2-dev : Depends: libpulse-dev but it is not going to be installed
So I check libpulse-dev:
libpulse-dev : Depends: libpulse0 (= 1:4.0-0ubuntu11.1) but 1:4.0-0ubuntu11.1+kxstudio1 is to be installed
Depends: libpulse-mainloop-glib0 (= 1:4.0-0ubuntu11.1) but 1:4.0-0ubuntu11.1+kxstudio1 is to be installed
From here I'm pretty much stuck. I'm aware that pulse is responsible for the sound, but I'm lost as to how to fix such an issue.
I also tried everything this answer had to offer: https://askubuntu.com/a/142808/130518
