How do I install Skype in Ubuntu 17.04 64 bit?
I am just running it from an original RPM folder, with a short cut to the launcher.
I cannot get the .DEB or .RPM packages to install.
What line do I need to use in the repository section for it to appear in the software manager?
Zanna
  • 72,312
Older versions of the Skype desktop app for Linux will no longer work from July 1 this year, Skype has said.
“All Skype for Linux client version 4.3 and older will be retired on July 1, 2017. To keep chatting, please install the latest version of Skype for Linux,” a notice on the Skype for Linux download page reads.
To install the latest Skype, download it from here
once downloaded you can either use Gdebi to install it, or just Just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo dpkg -i skypeforlinux-64.deb
Mitch
  • 109,787
Just go to Skype website and choose the version for your OS (Deb for Ubuntu). When it's downloaded, open the .deb file and it will open Software Center. Just click "İnstall".
(There's a bug with Software Center that install button doesn't work. I suggest you install GDebi package manager. You can find it in the Software Center, or you can install via terminal. It can install deb packages for you if Software Center doesn't work.)
Zanna
  • 72,312
