Is it possible to check internet speed using the ping command ?
Ping determines the time to receive a reply, which could be used to calculate the average round trip speed provided we know the internet addresses of some standard servers.
Is t possible to separate the round trip times into the going and returning times so that upload and download speeds could be separated ?
To my own surprise this acually seems to be possible: see here
However I would only recommand to use this methode in a LAN network. If you want to check your internet speed use speedtest
You can install it via apt:
apt install speedtest-cli
Then just run the command
speedtest
and it will measure you internet speed.
itssme
  • 194
Ping defines as 32/64 bytes data transfers from your side of web connection to remote side of.
Generally, you can think of possiblity of obtaining speed of internet connection
However, When you pinging, another situations may be in active, such as type of internet connection(adsl, fiber optic etc.)
One other thing we cannot eliminate is the connection distance between two remote server, for instance when pinging to google from estonia or india or anywhere else makes different solution due to distance of google server...
and also your internet sharing from other connections make your connection limit upper so transfer and communication gets slower.
finally, your internet speed verification not only element effecting ping speed actually so that you can not get clear conclusion to test your speed.
solfish
  • 1,591
