When I give
sudo apt-get install libqt4-dev
It gives this error
Read packet list ... Done
Deployment tree generation
Read status information ... Done
Some packages can not be installed. This may mean
That an impossible situation was required or, if it is
Using a deployed development that some packages required
They have not been created yet or have been removed from Incoming.
The following information can help you resolve the situation:
The following packages have unsatisfied dependencies:
 Libqt4-dev: Depends: libqt4-dbus (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
              It depends: libqt4-declarative (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
              It depends: libqt4-designer (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
              Depends on: libqt4-dev-bin (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4)
              Depends on: libqt4-help (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
              It depends: libqt4-network (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
              It depends: libqt4-qt3support (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
              It depends: libqt4-script (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
It depends: libqt4-scripttools (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
              It depends: libqt4-sql (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
              It depends: libqt4-svg (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
              Depends on: libqt4-test (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
              Depends on: libqt4-xml (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
              Depends on: libqt4-xmlpatterns (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
              It depends: libqtcore4 (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
              It depends: libqtgui4 (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but version 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4.1 is to be installed
              Depends on: qt4-linguist-tools (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4)
              Recommend: libqt4-opengl-dev (= 4: 4.8.5 git192-g085f851 dfsg-2ubuntu4) but it is not going to be installed
              Recommend: libqtwebkit-dev (> = 2.0 ~) but it is not going to be installed
And: Unable to fix problems, there are blocked damaged packages.
I run a VirtualBox image with a fresh Ubuntu installation, and everything works fine, so I suppose I messed up with my Host.
How can I solve the issue? Output is in Italian, it means I have broken packages. How can I identify them? I tried to instal by source, but again it complains of missing Lgl.
Thanks
EDIT1 When I give the command suggested by Rohit
sudo apt-get install libqt4-core
it outputs
 Libqt4-core: Depends on: libqt4-dbus (= 4: 4.8.5 + git192-g085f851 + dfsg-2ubuntu4) but version 4: 4.8.5 + git192-g085f851 + dfsg-2ubuntu4.1 is to be installed
               It depends: libqt4-network (= 4: 4.8.5 + git192-g085f851 + dfsg-2ubuntu4) but version 4: 4.8.5 + git192-g085f851 + dfsg-2ubuntu4.1 is to be installed
               Depends on: libqt4-script (= 4: 4.8.5 + git192-g085f851 + dfsg-2ubuntu4) but version 4: 4.8.5 + git192-g085f851 + dfsg-2ubuntu4.1 is to be installed
               It depends: libqt4-test (= 4: 4.8.5 + git192-g085f851 + dfsg-2ubuntu4) but version 4: 4.8.5 + git192-g085f851 + dfsg-2ubuntu4.1 is to be installed
               It depends: libqt4-xml (= 4: 4.8.5 + git192-g085f851 + dfsg-2ubuntu4) but version 4: 4.8.5 + git192-g085f851 + dfsg-2ubuntu4.1 is to be installed
               It depends: libqtcore4 (= 4: 4.8.5 + git192-g085f851 + dfsg-2ubuntu4) but version 4: 4.8.5 + git192-g085f851 + dfsg-2ubuntu4.1 is going to be installed
George Udosen
  • 37,534
