I would like to rename the disks in my system, so that I can comfortably differ between all the removable drives I have. I know that it is possible to assign different labels to single partitions, but I haven't read anything about renaming the actual drive itself.
The Debian installation image however managed to relabel the drive as seen below:
lsblk
NAME                  LABEL                  SIZE MAJ:MIN RM TYPE MOUNTPOINT
sdd                   Debian 9.0.0 amd64 n 115,3G   8:48   1 disk
├─sdd2                NTFS_36GB             33,5G   8:50   1 part
├─sdd3                FAT32_16GB            14,7G   8:51   1 part
└─sdd1                EXT4_72GB             67,1G   8:49   1 part
(I created and relabeled the Partitions myself)
So I would like to know how that works and how I can change the disklabel (/dev/sdx), not the label of the partitions (/dev/sdxy), myself.
And as far as I'm concerned this is not a duplicate, because I am NOT looking for a way to rename the drives partitions (which is what I already did), but the DRIVE ITSELF (see output of lsblk seen above: The drive is called "Debian 9.0.0 amd64 n", the partitions are called " FAT32_16GB" and so on.)
I would appreciate any help I can get.
Update:
Output of sudo file -s /dev/sdd:
/dev/sdd: DOS/MBR boot sector ISO 9660 CD-ROM filesystem data (DOS/MBR boot sector) 'Debian 9.0.0 amd64 n' (bootable); partition 1 : ID=0xee, start-CHS (0x0,0,1), end-CHS (0x3ff,254,63), startsector 1, 241827839 sectors, extended partition table (last)
Output of lsblk --output NAME,UUID,PARTUUID:
NAME                  UUID                                   PARTUUID
sdd                   2017-06-17-13-08-59-00
├─sdd2                2D530D7137CBDA43                       afc5a866-4b80-463d-9a01-d196a333dadd
├─sdd3                FD8F-3B99                              132b5e3d-3607-4327-a89e-c6b311f2c1cf
└─sdd1                5c8a0658-bcfb-41ba-8145-a1475e6ca4c7   cc2c2983-4cc5-4228-9cc3-5401b7d21803
Output of sudo fdisk -l /dev/sdd:
Disk /dev/sdd: 115,3 GiB, 123815854080 bytes, 241827840 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 32C4D45A-8930-4D9F-8C2B-1CD08A292466
