Is there any SIP-client for Ubuntu which has command-line interface? So, for example, I can make calls without using any GUI, just sending commands to the application.
Asked
Active
Viewed 2.4k times
There are lot of sip clients which support command-line.
Pjsua is a sip client. check this for features of pjsua
You can download pjsua from here
Rajesh Pantula
- 1,697
Exactly this https://docs-new.sipthor.net/w/sip_clients/sip_session/ from https://sipsimpleclient.org/
You only need to install sudo apt-get install sipclients
Check out the repos here: https://docs-new.sipthor.net/w/debian_package_repositories/
-2
you can do this with skype. see:
https://stackoverflow.com/questions/24480465/what-is-the-correct-com-skype-usage-with-linux
try:
skype --callto echo123
