I want to add a new machine to MAAS for commissioning and deployment using the MAAS CLI. What is the MAAS CLI command to add a new machine that supports IPMI power parameters?
James
  • 1,103
Here is an example of how to add a machine:
maas maasadmin machines create \
    hostname=<hostname> \
    fqdn=<hostname>.maas \
    mac_addresses=<mac_used_for_dhcp> \
    architecture=amd64 \
    power_type=ipmi \
    power_parameters_power_driver=LAN_2_0 \
    power_parameters_power_user=<ipmi_user> \
    power_parameters_power_pass=<ipmi_password> \
    power_parameters_power_address=<mgmt_ip_address>
Inputs:
hostname: whatever you want to label your new machine.
mac_address: The mac address of the adapter on the new machine that will receive the DHCP address and then reach back to MAAS for a PXE image.
ipmi_user/password: The user account on your machine's controller card (e.g. Dell iDRAC)
mgmt_ip_address: The ip address of your machine's controller card (e.g. Dell iDRAC)
The following is pulled from the MAAS api source code for creating a new machine.
   """Create a new Machine.
    Adding a server to a MAAS puts it on a path that will wipe its disks
    and re-install its operating system, in the event that it PXE boots.
    In anonymous enlistment (and when the enlistment is done by a
    non-admin), the machine is held in the "New" state for approval by a
    MAAS admin.
    The minimum data required is:
    architecture=<arch string> (e.g. "i386/generic")
    mac_addresses=<value> (e.g. "aa:bb:cc:dd:ee:ff")
    :param architecture: A string containing the architecture type of
        the machine. (For example, "i386", or "amd64".) To determine the
        supported architectures, use the boot-resources endpoint.
    :type architecture: unicode
    :param min_hwe_kernel: A string containing the minimum kernel version
        allowed to be ran on this machine.
    :type min_hwe_kernel: unicode
    :param subarchitecture: A string containing the subarchitecture type
        of the machine. (For example, "generic" or "hwe-t".) To determine
        the supported subarchitectures, use the boot-resources endpoint.
    :type subarchitecture: unicode
    :param mac_addresses: One or more MAC addresses for the machine. To
        specify more than one MAC address, the parameter must be specified
        twice. (such as "machines new mac_addresses=01:02:03:04:05:06
        mac_addresses=02:03:04:05:06:07")
    :type mac_addresses: unicode
    :param hostname: A hostname. If not given, one will be generated.
    :type hostname: unicode
    :param domain: The domain of the machine. If not given the default
        domain is used.
    :type domain: unicode
    :param power_type: A power management type, if applicable (e.g.
        "virsh", "ipmi").
    :type power_type:unicode
    :param power_parameters_{param}: The parameter(s) for the power_type.
        Note that this is dynamic as the available parameters depend on
        the selected value of the Machine's power_type. `Power types`_
        section for a list of the available power parameters for each
        power type.
    :type power_parameters_{param1}: unicode
James
  • 1,103
