Ubuntu 16.04 How to install rsync server for other systems to access via ssh using cron
Setup: system "prime" with Ubuntu 16.04 and a second hard drive just for backups.
/dev/sdb1 is mounted at /mnt via using blkid to get the uuid then adding a line to /etc/fstab
I created a subdirectory named /mnt/full/prime for the first backup, of the prime boot SSD contents.
--> Running the command:
sudo rsync -aAXv / --delete --ignore-errors --exclude={"/dev/*","/proc/*","/sys/*","/tmp/*","/run/*","/mnt/*","/media/*","/lost+found"} /mnt/full/prime
does indeed make a nice mirror copy of the root file system into that directory /mnt/full/prime
It is totally cool - like Robocopy with the /MIR option - it only transfers changes so runs a lot faster after the files have been copied the first time.
Now, to set it up for others to access, I found this article
How to Use rsync to Backup Your Data on Linux
It says to run the following command:
sudo apt-get install ssh rsync
it installed normally.
--EDIT: This turns out to be unnecesary. --END EDIT--
All of my systems have the passwordless login set up in both directions.
ssh-keygen
ssh-copy-id -i ~/.ssh/id_rsa.pub <target-system>
and I have no problem with passwordless scp copies and ssh.
So I then created a subdirectory under mnt/full for my next system "solar" - /mnt/full/solar and using ssh into the Raspbian system "solar" I issued the same rsync command but with the target directory being pi@prime:/mnt/full/solar
mkdir /mnt/full/solar
ssh solar
sudo rsync -aAXv / --delete --ignore-errors --exclude={"/dev/*","/proc/*","/sys/*","/tmp/*","/run/*","/mnt/*","/media/*","/lost+found"} pi@prime:/mnt/full/solar
but it prompted me for the password to pi@prime - rsync does not respect the normal passwordless login setup.
Once I entered the password the copy proceeded normally.
So now all seems well except this won't work as a daily cron job if it is going to prompt for a password.
The question is in the title: Ubuntu 16.04 rsync via ssh prompts me for password, how to make it a cron job?
