I am using ubuntu 10.04. I had installed php with the following command if that makes a difference:
sudo apt-get install php5 libapache2-mod-php5
The PHP version on my computer is 5.3.2-1. Will PHP be upgraded any further on this version? If so, where can I find out when the next upgrade will be released and what version it will be? Thanks in advance.
Jorge Castro
  • 73,717
ryy
  • 163
Programs aren't generally updated in Ubuntu unless they absolutely have to. The current version of the program at release time is what goes in the repositories. After that, only critical security updates are allowed. So, you'll either have to upgrade Ubuntu or manually download the current version of PHP.
William
  • 7,720
After Ubuntu is released, it is considered stable. That means having as few changes as possible. Only necessary changes are added. Such updates are called Stable Release Updates (often called SRUs). You can read more about that process here: https://wiki.ubuntu.com/StableReleaseUpdates
